Question about HP LaserJet 2420 Printer
What kind of error is 49.0665
When trying to print,my printer returns a error message of error 49.0665 service error
    Champion:
  • HP Expert
  • 312 Answers
This is a firmware error, that may be caused by corrupt printjobs or network issues. Try to see if you can narrow down the problem to a specific application and also check the URL below for any firmware updates. The problem can also be caused by faulty firmware dimms, memory dimms, or a faulty formatter board, but the message normally persist when this is the case.
Go to htpp://www.hp.com/
support/LJ4200 or htpp://
www.hp.com/support/
LJ4300. Select Download
Drivers and Software. Check
for the latest firmware image
version at the bottom of the
page. If this firmware image
is newer than the one
installed on your printer and
your printer can receive a
firmware update, download
the newer firmware upgrade.
Not all HP LaseJet 4200/
4300 printers can receive
firmware upgrades.
Posted on Jan 31, 2015
SOURCE: Printer Stopped Working
is this still current?
Posted on Aug 19, 2008
pdouglasss
  • 125 Answers
SOURCE: HP 2430n Service Error 494C02
Hi atrowbridge:
The error code 494c02 is a firmware issue and needs to be updated. You can go to www.hp.com for the latest firmware updates for your printer.
pdouglasss
Posted on Jan 09, 2009
SOURCE: Does not print red, print heads do not return to left parked area
The printhead not moving to the left I think I can solve. Open the top cover, the yellow light on the paper feed button wil come on solid, press and HOLD this button until you hear the print head assembly make some noises (about 10 to 20 seconds) then release the button and then the printheads will move and park on the left so you can remove the printhesd(s)
Posted on Jan 22, 2009
rulds2008
  • 3866 Answers
SOURCE: The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Posted on Apr 23, 2009
  • 2246 Answers
SOURCE: Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Posted on Jan 14, 2011
900.80 rip error
Step 1: Turn off the printer for 30 seconds or longer to clear its memory
Do not power the printer off and on too quickly. Doing so can cause a power issue and
create this type of issue.
Step 2: While the MFP is off, clear any pending print jobs from the computer or the network queue.
This will prevent any corrupted print jobs from being re-sent to the MFP when it is powered
back on.
Step 3: Did the error message return?
Yes: If the 900.80 error returns when the printer is powered up or when you try to print again,
continue with Step 4 or go to Contacting Lexmark.
No: If the 900.80 error does not appear on the printer screen, use the printer operator panel to
print a menu settings page. If the error does not return, continue using the printer.
Step 4: Power the MFP off and disconnect all communication cables (i.e., the parallel, Ethernet,
and USB cables). The only cable that should be connected to the printer at this time is the
power cord. There might be a problem with either the printer, a communication cable, or the
print job itself. If possible, connect the printer's power cord directly into a grounded wall
outlet.
Step 5: Power on the MFP again.
Yes: A service call may be required. Please contact Lexmark Technical Support or a
local authorized service center in your area for additional assistance.
Replace scanner control card (SCC) first, if no fix replace FB CCD Asm
Parts number
40X2194 - SCANNER CONTROL CARD
40X2193 - FLATBED CCD ASM
to print a menu settings page. If the error does not return, continue using the printer.
Jun 18, 2011 | Lexmark X782e Laser Printer
My Lexmark printer is showing 122.03 service fusher error what can i do
This error normally requires a service call. However, certain rare occurrences, such as a a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 122.03 error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to test this.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
Contacting Lexmark
Please contact Lexmark Technical Support for additional assistance.
Jun 10, 2011 | Lexmark X543dn Laser Color All-In-One...
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
Error code 917.00
Step Action 1 Turn off the printer and let the printer sit, powered off, for one minute. 2 Power the printer back on. 3 If the 917 error does not return on power-up, try printing a few pages. If the error does not return during printing, this may have been an isolated incident. Continue using the printer as before, but pay close attention to it for the next few days to see if the error returns. 4
If the error returns on power-up, as soon as you try to print, or re-appears at a later time, inspect the transfer roller. (Click the links in the steps below for images.)
  1. Turn the printer off.
  2. Open both the lower front cover and the upper front cover of the printer.
  3. Remove the toner cartridge and place it aside.
  4. Look at the transfer roller. Make sure nothing is stuck on the roller or wrapped around it. If you find any obstruction, try your best to remove it without damaging the transfer roller or knocking the roller loose.
  5. Make sure the transfer roller is not loose or damaged. If the roller is damaged, the roller will need to be replaced. Please contact Lexmark Technical Support or a local authorized service provider for further assistance.
  6. Spin the transfer roller. Make sure it spins freely.
  7. If the transfer roller appears to be fine, reinstall the toner cartridge and power the printer back on.
  8. Try printing again to see if the error message returns.
If the 917 error still will not clear, or if the error continues to occur intermittently, the printer will likely require service. Please contact Lexmark Technical Support or a local authorized service provider for further assistance. See Contacting Lexmark below for more information.
Jan 11, 2011 | Lexmark T642 Laser Printer
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
103 service ITU ERROR
lexmark basically has said that if this error doesnt clear by powering off the machine and powering it back on again then it will need to have a service call. this error means there is a problem with the itu belt assembly.below is what they say. the steps were to pwoer it off and back on again using a grounded wall socket
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table.
Step Action 1
No:
Nov 19, 2009 | Lexmark C760 Laser Printer
994 Service Density Sensor Error Lexmark C912 Color Laserjet
What the error means:
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error.
What to do:
This error normally requires a service call. However, on certain rare occasions, such as a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 994 Density Error message to appear. In such cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to check.
Step Action
1 Power the printer off, wait ten seconds, and then power the printer back on.
2 If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to 'Contacting Lexmark' below.
Contacting Lexmark
When calling for service you will need to know your printer model type and serial number. If you need help locating this nformation, click here.
Call them while you're near the printer in case the technician asks you to perform a task involving the printer.
Jun 15, 2009 | Lexmark C912 Led Printer
My lexmark is showing a code of 1201 and it will not print. (X4270)
Kindly try this:
- Power the printer off.
- Remove all cables from the back of the printer.
- Reinsert the power cord.
- Switch the printer back on.
- Check the operator panel to see if the 1201 error message is displayed.If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Mar 11, 2009 | Lexmark X4270 All-In-One InkJet Printer
HP LaserJet 2420 Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
