Question about Tascam CD-302 Version 4.0 Dual Deck CD Player
My Tascam 302 cd player reed error 4 in the right side and do not play
5 Suggested Answers
mjap
  • 107 Answers
SOURCE: cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Posted on Jan 30, 2008
SOURCE: cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Posted on Jun 18, 2008
SOURCE: Will not play a Memorex cd-rw
try again! burn an audio cd, but burn it at max 12x speed!!
Posted on Oct 28, 2009
projdoc
  • 2237 Answers
SOURCE: cd player ejects will not play
can't read the disk. either the disk is dirty or the lens on the optical pickup is. get a lens cleaner disk from any electronics store.
Posted on Jan 15, 2010
Tascam CD A500 'No Disc' error message
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
May 01, 2008 | Tascam CD-A500 CD Player
Where can I purchase a replacement cue button switch in the UK?
You would have to get a repair shop, Order one for you ,Or get them to repair it for you. Have you tried to contact, Customer support if the company has it?
Nov 07, 2012 | Tascam CD-302 Version 4.0 Dual Deck CD...
My tascam cd-1500 dj left side only display good day while the right side is fine
how can i b deck going on my tascam x1700 from gd day when i got deck a working i cant remmber what i pressed can any one help
Aug 25, 2011 | Tascam Cdx1500 Dual CD Player CD Player
The left hand deck has difficulty playing CDR discs.
the lens wants to be clean.if that does not correct the problem.the lens needs to be replace.good luck.
Feb 28, 2010 | Tascam CD-302 Version 4.0 Dual Deck CD...
Need cords
8-pin mini din cables p/n: 9109030600, you can buy them from any authorized TASCAM/TEAC dealer.
Jan 11, 2010 | Tascam CD-302 Version 4.0 Dual Deck CD...
Oct 28, 2009 | Tascam CD-RW4U CD Recorder
I have a Tascam CD-01u CD player that has a CD that will not eject. It will play the CD, but only clicks a lot and displays "Error 2" wihen I attempt to eject it with the remote and/or the machine's face...
I have a Tascam CD-1u Professional that load's the CD and say nodisc once it is done loading. this unit dosen't seem to be reading the CD what is the problem
Oct 16, 2009 | Tascam CD-01U CD Player
I keep getting Disc read errors! when I put a CD-R in my Tascam CC-222. I thought the problem was with the discs so I bought more ... Sony CD-R. Still the same problem. Help
Either the player doesn't except this format which many don't read burnt discs. If it plays factory made discs, than it doesn't except burnt formats. If it doesn't read any discs, than the laser eye may need to be cleaned with rubbing alcohol and cotton swab
Apr 24, 2009 | Tascam CC-222mkIII CD Player / Recorder
Cd player reads disc error
(TIP)
Jan 28, 2008 | Tascam CD-A500 CD Player
Tascam CD-302 Version 4.0 Dual Deck CD Player Logo
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
