Question about GE JVM1440 Microwave Oven
How do you replace a handle on a ge jvm1340ww microwave oven
There is only one screw that i see to remove the handle... This screw is at the top of the handle. There is an additional screw in the bottom of the handle but you cannot access the screw...
MicrowaveSvc
  • 9098 Answers
SOURCE: Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Posted on Apr 01, 2009
SOURCE: need to replace GE Spacesaver microwave door handle
never attempt to repair or replace the handle or any part of the door as this almost allways will lead to microwave leakage this will cause most certain death..
replace door or replace the unit today the uniy a very inexspensive..
nbcrca:)
Posted on Apr 11, 2009
milten1
  • 1304 Answers
SOURCE: Problem: How can I replace the door handle on a
ok start over
you need to be looking at the inside of the door
the frame around the glass the choke
will pop off,,
take a small flat head place it between the choke and the frame down by the hinge. pry ever so carefully it will pop out slide the screwdriver around the edge until the whole choke is dislodged
once the choke is off
you will see the two screws for the handle
you may need to lift the latch mechinism to get to the bottom one
once your done you can simply push the choke back it place you will here it snap
be careful the choke is very brittle
and will break if bent
Posted on Oct 10, 2009
Ge spacemaker xl jvm1340WW error message e2
please make this step , use the multimeter, and fix it. Merry Christmas.
F2 Oven cavity thermistor closed Check oven thermistor for continuity. Replace if zero or infinite ohms.
Dec 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave model JVM1650CH01. Trying to replace door handle." I have removed panel on inside of door and removed 2 screws to handle. It appears that there are screws holding the outside cover of door...
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
May 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
Cannot remove handle to replace it.  The handle broke on top.
You must pry out the plastic strip that surrounds the window on the inside of the door to reach the top screw that holds on the handle. Be prepared to spend a pretty penny on the replacement handle as well.
Feb 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jan 27, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Replacing GE microwave door handle
1. order at http://www.a-1catalog.com/gemidohaw.html
2. Open the door to the microwave. The top screw is obvious. Take it out.
3) Use a flathead screwdriver or putty knife to remove the inner moulding. THis is the central thing you'll see -- the outside is the frame of the door and the inside is the frame of the screen/window. The MIDDLE thing is the one you want. It's is clipped onto the screen/window frame, so put the screwdriver in on the edge closer to the door frame and gently lever it out. There are a lot of clips. BE CAREFUL -- if you are unsure, take to an appliance repair shop that can properly test for leakage!!!
4. The lower screw will then be evident. Take it out and the handle... or shards of it in my case... comes off.
Jan 04, 2008 | GE JVM1440 Microwave Oven
Oct 08, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Handle
when door is open on the edge you wil find a plastic strip .remove carefuly with flat screw driver .when removed youwill find the screws holding the handle undo screws and replace .dont 4get to replace plastic strip
Apr 23, 2007 | GE JVM1440 Microwave Oven
GE JVM1440 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
