Question about Toshiba Satellite A105 Notebook
My toshiba satellite wont boot from cd rom
I want to re-intall windows on my toshiba satellte laptop and the system wont boot from cd rom
  • Anonymous Mar 21, 2014
    Can't boot system
    President:
  • 2,559 Answers
Press F12 while booting
Posted on Jan 23, 2009
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
I need to reset my laptop
Hello, here are the steps to resetting your computer.
Reinstall Windows from a Disk
1 Turn on your Toshiba Satellite. Insert your recovery disk or the original Windows operating system DVD
into the Satellite's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba 173" Satellite L555S7008 Intel...
I have a problem in my Toshiba pro L300 laptop. I have upgrade the operating system from Windows vista to windows 7. After that the CD-ROM does not detect any CDs and DVDs. I have seen the CD-ROM driver in...
Hi, this is a common problem, I have put a link below to do a free driver scan, hopefully it will detect the drivers you require.
http://www.opendrivers.com/modeldriver/Toshiba_notebook_Satellite%20M50-driver-download.html
Aug 04, 2010 | Toshiba Satellite Pro L300 Notebook
How can I force a cd boot on a toshiba satellte A135-S4477
You need to hit the function key on reboot that takes you to the BIOS settings. In the BIOS settings there will be an option to change the boot order. Make sure the CD is the first device to boot from. If the machine fails to boot from CD after this, then either the CD-ROM in the device is not a bootable CD ... or the drive may have issues.
Cheers!
Sep 24, 2009 | Toshiba Computers & Internet
Toshiba satellite 1805 s204 "media test failure, check cable"....
Did you install the windows system etc? If not boot from the system restore cd and it should work. If it will not boot from the cd-rom then more damage was done then was apparent and the unit would require factory qualified repair. Be sure of the cost before committing to repair since on laptops sometimes it is cheaper to replace the repair. Good Luck
Jul 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Can't change the boot sequencefrom bois..for Toshiba Laptop.
If you successfully selected CD ROM, try saving the changes you made and then ensure that you have a bootable CD in the drive when you power on the system.
Jun 27, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Installing XP on a toshiba satellite l45 s7424 laptop
Boot your computer from your xp intallation cd, windows xp will install alright.
May 28, 2008 | Microsoft Windows XP Home Edition
Regarding Toshiba Satellite Laptop(CD Rom faulty so how to reboot XP)
try to check the bois if it is capable on booting in USB. you can load your copy of windows in the USB and boot it there...or try to look for another laptop that has the same CDROM connector.
Oct 24, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
405 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
