Question about Coleman Heating & Cooling
I have a coleman preidental 2 model 3115b750 .the motor tries to run,but just growls
  • Coleman Master
  • 6,674 Answers
Possible start capacitor defective, should have that checked first. Please don't try yourself if not familiar with capacitors as they can give a fatal electrical shock if not handled properly.
Posted on Jan 28, 2013
Wirinmg diagram for SEARS12" tablesawMod#11324181 Serial# 7297Poo56
Please contact Sears on this, we do not have these diagrams here.
Dec 02, 2016 | Pool & Spa
How many watts does a coleman 3115b750 draw
Normally, it's the amperage draw, that is of concern. It is normally printed on the manufacturers data sheet some where. Watts are typically the output from it, and can be found by multiplying the voltage, by the amps drawn. ie- 220v x 50amps =11,000 watts output. 110v x 15 amps = 1650 watts of power. There is a formula to then calculate the BTU's from the resulting answer. You can multiply the watts by 3.412, to get the BTU output.
Sep 25, 2014 | Coleman Heating & Cooling
My Emerson model k55hxjcp-2593 electric fan motor has 5 wires connecting to the motor. The replacement motor only has 4 wires. I need to know how to connect the new motor seeing there is only 4 wires
the motor should have wireing diagram on side. i would expect 2 of the wires go to a run capacitor & the other 2 are your 110 or 220 depending on unit need.
Jun 17, 2014 | Coleman Mach III Air Conditioner
Lg ldf7932ss growling noise at wash cycle
The LG is known for the main motor bearings (2 small cheap) bearings that are of poor quality and become noisy (growls) after a period of time. I pulled the motor and replaced the Korean bearings with quality German equivalents. This is cheap and solves the problem. (the front bearing closest to the plastic pump is the culprit.
Mar 15, 2013 | LG LDF7932ST Builtin Dishwasher
Kenmore 16532 dishwasher,three years old. It has slowly gotten very noisy. I have stripped down everything I can access from the tub, including the chopper. I can't find any problem. It is quiet while the...
It could be 2 things:
a) water obstruction in the spray jet ports causing uneven rotation of the spray arm.
This uneven rotation will eventually wear out the motor bearings.
Fix: clear out any clogged spray jet ports.
b) the motor bearing are already shot, and they're growling and howling in pain as the motor grinds them to death.
Fix: replace motor - new bearings will come with the new motor.
Alternate Fix: replace dishwasher. Often new motors are so expensive, replacing the whole unit is the bast option, especially with Sears/Kenmore (where parts are expensive)
Try: www.SearsPartsDirect.com.
I tried the sears parts web site for you, but you model number came back to a Bissel carpet cleaner.
Oct 15, 2010 | Kenmore 24 in. 16532 - Multiple Color...
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
I have an HP J6460 that growls during startup, then ''Paper Jam''s
If there is a manual feed, try feeding a sheet of paper through.
The problem is that the motor is being told to move the paper, and nothing happens. The growl is the motor/gears attempting to move the paper.
The motor may be dead. If not, then there is SOMETHING jamming up the gears. Clear out the gears and try again.
If that fails, go buy a laser printer based all-in-one (much cheaper per printed page).
Feb 07, 2010 | HP Office Equipment & Supplies
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
53 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
