Question about ICOM Informatique GP-270ML GPS Receiver
Communication to Offshore Navigator light
I have a problem communicating GPS info from my 270ML to the chart plotter (a PC)When first connected it gets a GPS fix but looses this after a minute or so. Then at occations I get a new fix, which disappears rapidly. The error message in the chart program is The program receives a telegram which is longer than the specification for NMEA 183 Anyone able to give me some guidance?
The internal memory battery is dieing. It will eventually stop completely unless you get a new battery installed.
Posted on Aug 11, 2008
Is their a internal battery in sitex colormax 11
Yes. There is a battery backup to store memory. Read all about the Sitex Colormax chart plotters here:
http://www.si-tex.com/product_manuals/Chart-Plotters-3-08.pdf
Apr 28, 2014 | SI-TEX COLORMAX 11 GPS Receiver
I WANTED to reinstall Offshore Navigator on my laptop because it was corrupted so I deleted the program before getting my program CD ONLY to find out I misplaced it. I have the program on my home...
Contact them direct. They should have a record of your registration.
How to Contact Maptech
If you have a question and you haven't found the answer here in the Help pages, Maptech's technical support staff
will be happy to assist you. Support is available from 8:30AM to 5PM Eastern Time, Monday through Friday:
E-mail:
support@maptech.com
Fax:
(978) 792-1095
Internet:
http://www.maptech.com/support
Offshore Navigator Google Search
Sep 30, 2017 | Maptech Offshore Navigator (EMSWOS)
Connection to PC for Nav software
Assuming you have GPS input to your 1732 (i.e. GP310/320 sensor), you'll need a 7 pin NMEA data cable (000-154-028) wired to a D-sub 9 pin (serial) plug. The shield goes to pin 5, blue to #3, & white to #2. Jumper pins 7 & 8 together. The 7 pin cable goes to Data port 3 of the 1732.
Jul 12, 2010 | Furuno Navnet 1732 GPS Receiver
Is SOG (speed over ground) displayed?
yesss! On the top line, click on " view", then click on " on water mode"
you will then have all the navigations needed for running your boat...better yet, click on "sphere" on the bottom line and see your boat showing your displacement on the chart...I love it !!!
May 03, 2010 | Maptech Offshore Navigator (EMSWOS)
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Mar 22, 2008 | Raymarine RL70CRC GPS Receiver
Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
ICOM Informatique GP-270ML GPS Receiver Logo
113 people viewed this question
Top ICOM Informatique GPS Experts
Steve
Your Consultant
Are you an ICOM Informatique GPS Expert? Answer questions, earn points and help others
