Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
Windows has shut down - Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
    Genius:
  • 1,669 Answers
Yes, so start it up again by putting in your system disk and doing a system repair!
Posted on Jan 14, 2013
G580 WILL NOT SHUT DOWN
In windows 8, Set to High Performance, set Sleep and Hibernate to Never, set What to do when Lid is closed, adjust Advanced Power Options to your preference. Always Shut Down the Laptop and unplug when not in use to prevent damage due to power surges. Use this procedure: http://techmell.com/windows-tips/change-windows-8-power-options-launch-setting-details/
Feb 24, 2013 | Lenovo G580 - 15.6" - Core i5 3210M -...
Windows not shutting down
If there are programs (Norton, McAfee, other bigger programs) running in the background it will take a while for Windows to shut down. If you can't wait for it to shut down, you can press/hold the power button down for a few seconds and Windows will shut down.
Jul 07, 2012 | Microsoft Windows XP Home Edition English...
Toshiba Tecra M10 hanging when windows is shutting down after an update
Are you sure you are not too fast or impatient for it. Sometimes after doing updates it might take awhile to get past the Windows is shutting down...
Give it some time and see what happens. If after 15 minutes it is still there, press and hold the Power Button until it shuts off then Reboot. Try shutting down again and see if it hangs.
May 14, 2012 | Computers & Internet
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Dec 19, 2010 | Computers & Internet
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
System power won't shut down when Windows shuts down.
if same system asking about hp a1320n
drivers and bios updates
try upadating all to see if corrects
May 15, 2009 | HP Pavilion Media Center a1320n PC...
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
