Question about ASUS Eee Lamborghini VX6-PU17-BK PC Netbook
NUMBER AT MY KEYBOARD NOT FUNCTION
1,3,5,6,8 NOT FUNCTION
    Problem Solver:
  • 6 Answers
Try to remove your keyboard this problem occurred when there is stick or anything els cause your keyboard not work properly.
Posted on Jan 14, 2013
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
Function keys doesn't work
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Nov 11, 2012 | Compaq Keyboard
Lost my e recovery management system
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Oct 15, 2012 | Acer Aspire 5920-6727 Notebook
What can I do to unlock my mouse
1. Locate the "function key" on your keyboard (F1 through F12) that has an icon of a touchpad. This is generally a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
2. Press and hold the "FN" key, usually found in the lower left area of your keyboard.
3. Press the touchpad function key ("F#," with the "#" representing the number 1 through 12 that you located in step 1), and then release both keys. If this does not enable your touchpad, try holding the "FN" key down and pressing the "F#" key twice in a row.
Sep 29, 2011 | HP Computers & Internet
I pressed some keys on the computer and now when I use the computer keyboard when I type o I get the number 6 and when I time i Iget the number 5. what did I do I am using a different keyboard as I type...
Hi Carol,
It seems that the function key (Fn) on the bottom left of the keyboard is stuck or jam. Try hitting the key multiple times or raise it with your fingers. Then try to press I and O again. Below the is image of the key you need to press and clear the jam from. You can also pat the keyboard/ laptop from at the bottom in case the jam wont clear by pressing the key.
Fig 1 : The function key
Fig 2 : The the shown below have multiple icon, those are activated by pressing Fn (function key)
Regards,
Shrey
Jun 04, 2011 | Acer NSK8458AN Keyboard
WHEN I PRESS U I O P J K L ON laptop, it type 4 5 6 - 1 2 3
try pushing the key marks "fn" and "F11" at the same time on your key board.
Feb 28, 2011 | Computers & Internet
Where is the Fn key an a dell keyboard?
This is a simple problem, due to the size of laptops, the manufacturers cannot fit on a normal number pad as on a standard keyboard, so what they do is use a function key to turn a portion of the keyboard in to the number pad.
to get rid of this you need turn the 'number lock' off this may be a single key or a combination.
for my laptop its:
press together; the function key (normally 'Fn' bottom left) and the number lock key (Num Lock).
hope this sorts out the problem.
May 30, 2010 | Acer 91.63X07.001 Keyboard
How I set the speed dial for the UF-8000 fax machine
press
function
74
set
119
set
enable one touch mode
set
stop
Press
Function
72
set
press a yellow key on the keyboard such as 01
enter fax number
enter name
set
continue with 02 or press stop
press
function
62 set
print directory sheet
Jan 26, 2010 | Panasonic PanaFax UF-8000 Laser Fax
About three of my number keys do no work. .you think this will require a new keyboard
there are little rubber buttons under your keys that wear down over time. that sounds like what has happend you should replace your keyboard.
Feb 27, 2009 | Gateway Solo 1400 (7003934) Keyboard
ASUS Eee Lamborghini VX6-PU17-BK PC Netbook Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
