Question about Whalen Furniture Whalen - Swinging Floater TV Mount - FPGTFL-DG
Instructions to set up install
How to remove handles
I have extracted the legend of figure 5B of the installation instruction here for your reference:
Remove handle from the faucet by loosening set screw (1) and pulling off handle. Once handle is removed, loosen set screw (2) from the bottom of the handle, remove accent (3), replace with new accent, tighten set screw (2), replace handle on faucet and tighten set screw (1).
Here is the link for the installation instruction:
http://www.deltafaucet.com/media/MandI/40033RevC.pdf
Dec 21, 2013 | Delta 2565-217 Botanical Double-Handle...
Settings I get into
You are seeing the installation instruction codes/parameters. You will need to get the installation instructions to interpret & see if you can change the differential
Dec 06, 2013 | Honeywell Rth6350 5-2 Programmable...
Where can I find instruction for installing a wire hoist?
I found this set of instructions to be very detailed and helpful when I had to set up my wire hoist. Good luck and stay safe!
http://voices.yahoo.com/how-install-wire-rope-hoist-7673214.html?cat=6
Nov 21, 2013 | Hoisting
How to format my nokia 9300i
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Oct 14, 2010 | Nokia 9300i Cellular Phone
Reset to manufacture setting
In order to reset to manufacturer settings, you will need to perform an Erase and Install, which requires the installation DVDs that came with your computer.
If you do not have these you can order a replacement set through 1-800-MY-APPLE.
If you are running 10.5 (Leopard), follow the instructions in this article to perform an Erase and Install:
http://support.apple.com/kb/HT1544
If you are running 10.6, follow the instructions in this article:
http://support.apple.com/kb/ht3910
Aug 13, 2010 | Apple MacBook Pro 154 in (MA895BA)...
EXA14248 lost instructions for set up. HELP
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jun 07, 2010 | Uniden 2.4 GHz Expandable Phone System...
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
How can I restore my computer to factory settings?thanks
Usually, every PC has a restore DVD. Try to boot from it and follow the instructions on the screen. Don´t forget to select "clean install" during the installation procedure.
Cheers.
Sep 19, 2009 | Dell Latitude D600 Notebook
Need instlation insructions
Here's the installation and operation/programming instructions for your lock set.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Weiser and Kwik set both sold and marketed the same lock under their own brand names, as Weiser was the manufacturer, these instructions apply for your lock set.
Hope you find this Very Helpful and best regards!
Jul 30, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Installing adobe premiere elements 7
SSE2 instruction set is a new set of instructions that has been built into the processor chips usually to enhance the performance of the computer. If you are using an older computer/processor, (possibly manufactured before 2001, when the SSE2 was introduced) you may not be able to install the applications that require the SSE2 instruction set on your computer.
Oct 24, 2008 | Computers & Internet
Whalen Furniture Whalen - Swinging Floater TV Mount - FPGTFL-DG Logo
22 people viewed this question
Top Whalen Furniture Televison & Video Experts
Electro Med Services...
Are you a Whalen Furniture Televison and Video Expert? Answer questions, earn points and help others
