Question about Air Conditioning and Heat for GMC Terrain
Ac quit working on 2010 gmc terrain
Had intermittent issue while under wrranty where ac system would not cool. dealer, of course, never found any problem. now has quit cooling completely. don't know if it's a related issue or not, but occasionally the radio will just not work when you start the car. usually fixes itself after a few restarts.
    Genius:
  • 1,669 Answers
Could be! Perhaps there is an intermittent ground strap that is not making good contact. They are all over the place attached to the chassis and frame of the truck. Under the dash are the ones for the radio, and the radio antenna is the other ground where it connects to the body underneath. The Ac grounds follow the compressor lines.
Posted on Jan 14, 2013
How do I set daylight savings time on my 2011 terrain
Suggest contacting a GM/CHevy dealer. I beleive there is a TBS out on this issue. Had same problem with a 2010 Equinox
Jan 15, 2015 | 2011 GMC Terrain
Gmc transmission diagram
Don't really know. But it is labeled ETAC in the fuse panel under the hood.
Sep 08, 2014 | 2010 GMC Terrain
What are the programing instructions for gmc terrain keyless remote fob?
According to a website I found for you, if it's a 2010 model you can't do it yourself. The site, which has much more information on the subject that you may want to read, said: "There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Try a locksmith before the dealership, they are usually 50% the cost."
The site also went on to say that it might be a good idea to go to your dealer (or call them) with your VIN number to see first if there have been any related recalls. Here's the site this info is from:
Key Fob Remote Programming Instructions 2010 GMC Terrain Key Fob Remote...
Aug 30, 2014 | GMC Terrain Cars & Trucks
My 2010 GMC terrain is making a knocking noise when air conditioner is on. Had the timing chain replaced but dealer now says it is activator that needs replaced for additional $600. Is this possible?
It's POSSIBLE, although it may or may not be true. Is this a continuous knocking noise with the AC running, or does it just knock a few times, then stop? If it's continuous, does it change in speed with the engine speed?
At any rate, that vehicle SHOULD still be under warranty; the dealer should be taking care of all of that for no charge.
Jul 14, 2014 | Air Conditioning and Heat for GMC Terrain
Hi, If I turn my 2010 GMC Terrain on , the heat
The heat shouldn't have anything to do with your car turning off and on. If there is a knocking while the heat is on then you probably have a heater motor going out in you.
Oct 28, 2013 | Air Conditioning and Heat for GMC Terrain
Cruise control stopped working on 2010 gmc terrain is there a fuse for this or do I have to take it to dealer
It has a fuse, but may not be listed on the fuse panel. Your owners manual should have a complete list of every component on each fuse circut.
Mar 08, 2013 | 2010 GMC Terrain
Why want GM put in after market car starter?
Becaus they want to sell you a starter. If you check the price you will see that the GMC starter will cost about 3 or 4 times as much as an after market starter. Parts are a high profit item for dealerships. If you bought enough parts to build a complete GMC Terrain from your dealer it would probably cost $200,000.00. A lot of local repair shops will only do AC Delco parts as well.
Oct 28, 2010 | 2010 GMC Terrain
Where is the oil filter on the 2010 gmc terrain 2.4
The oil filter on the 2010 GMC Terrain is located in the engine compartment. You'll need a short depth 1-1/4" socket wrench to loosen the cap. The cartridge is in the canister under the cap.
Sep 20, 2010 | 2009 GMC Envoy
Air Conditioning and Heat for GMC Terrain Logo
736 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
alibaba69
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
