Question about Dual Xr4115 Mechless Digital Media Receiver 200w
I installed a xr4115 dual digital media receiver in my 1997 jeep cherokee, I have power but no sound. I doubled checked the speaker wires and still nothing. I am really frustrated
One side of the door speaker wires is exactly what it is in dash, but passenger side door wires are different than what is in dash. This is crazy I have always had somebody do it for me, but then they seem to get stolen out of my car, so I am doing it myself. Thank you
SOURCE: Dual MXD55 W/6/5 SP CD Problems
Why does the red light flash when accessory is switched off and the face plate is removed?
Will it drain the battery?
Posted on Mar 17, 2008
  • 35 Answers
SOURCE: how do you check the fuse on my dual car stero
it shud be in the back of ur unit rite where the wires are ,plug th wires off & ur fuse shud be rite there.
Posted on Jul 15, 2009
sixohthree81
  • 33 Answers
SOURCE: no sound dual xhd6420 92 accord lx
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
Posted on Feb 26, 2010
kenw392
  • 2226 Answers
SOURCE: Just installed Dual XDMA6330 has no power no lights no sound
the red wire needs to go to a switced power source. unless both the red and yellow wires are getting power, the deck will not turn on.
Posted on Mar 12, 2010
SOURCE: i just installed my dual xdm7615 and it wont turn,
Check the radio fuse and the auto fuse
Posted on Sep 10, 2010
XR4115 display. Not working
Hi Robert
Tap it & move it... any flickers on display
LCD displays have often use a flat copper ribbon connector that gets loose or bad connections.
Just releasing it & re inserting the ribbon cable often does the trick
Some use a fine carbon film on the glass connector.
Dont make the mistake of cleaning this fine carbon off when cleaning. Or it's done!
Cheers
Digital Media Receiver LCD repair YouTube
Mar 13, 2016 | Dual Xr4115 Mechless Digital Media...
I installed a dual xr4115 car stereo in my 1997 jeep cherokee, it has power but no sound. I made sure all speaker wires were hooked up correctly but still nothing.
I have the same problem: Has power but no sound. My installation is in a 1994 Mazda B4000. I put a DMM on each speaker wire and they all read 55 Ohms, so the speakers are good. I also swapped out the head unit at the store to rule out manufacturing defect. All looks good but still have the same issue. Any help would be appreciated.
Jan 14, 2013 | Dual Xr4115 Mechless Digital Media...
I have a mazda mvp 1993 v6 and i need what each coler and what eachean for a radio help me
If this is a new radio you are installing, these are the existing Mazda connections:
In joint box: BLU/BLK wire from 15A CIGAR fuse (accy/run power); BLU/RED wire from 15A ROOM fuse (always hot power).
LF speaker: RED and RED/BLK; RF speaker: RED/YEL and ORG/BLU (or RED/WHT); LR speaker: BRN and BRN/WHT, RR speaker: BRN/YEL and BRN/BLK; L door woofer: GRN/BLK and GRN/ORG; R door woofer: GRN (or GRN/WHT and GRN/RED
Sep 27, 2012 | Dual New Xr4115 Mechless Digital Media...
Wire touched bare metal and now it wont turn on.
did you check the fuse for the stereo? sometimes if the wires touch it will burn out a fuse.
May 11, 2012 | Dual Xr4115 Mechless Digital Media...
I tried to wire a jvc kd-r320 in a 1996 jeep grand cherokee, hook it up and i got no lights or sound, when i turned on the jeep lights a loud buzzing sound came over the speakers?
You have the live connected to a speaker, recheck the wiring diagram. Red is the acc power, Black Neutral usually and yellow is direct power from battery. Wire just these and check if you have power and then do the speakers after you have that much working.
Apr 29, 2011 | JVC KD-G710 CD Player
Wiring diagram for jeep 1997
1997 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Red/Gray
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Orange
Car Radio Antenna Trigger Wire: Green/Red
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 19, 2010 | 1997 Jeep Grand Cherokee
97 jeep grand cherokee no sound from radio tested radio out of car it works. old owner had amp under back seat and cut into speaker wires in harness reconnected but still on sound
You will need to trace the speaker wires to see if they are disconnected anywhere in the harness. are you sure the speakers are OK? Fopr wire locations on the radio try going to: http://www.installdr.com/ They list the pin locations and wore coding you will need.
Good luck
Feb 20, 2010 | 1997 Jeep Grand Cherokee
1997 jeep grand cherokee idles low and cut out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First would probably try cleaning the throttle plate with carb cleaner and reinstalling the old idle control valve or at least double check the new one to make sure its installed correctly and sealed usually with a o ring.
I would also suggest you have codes read to see if it has any fault codes as you could have a sensor or wiring problem causing the computer to not be able to control the idle speed correctly.
Dec 31, 2009 | 1997 Jeep Grand Cherokee
I need speaker wire info for 97 jeep grand Cherokee please
HERE U GO. THIS IS ALL THE WIRE COLURS.
Feb 12, 2009 | 1997 Jeep Grand Cherokee
1997 Jeep Grand Cherokee Factory amplifier
I have the file on my other computer - search other bulletin boards. Check with Crutchfield help desk.
Input wires are the speaker wires from the Amp head/receiver (so you can go to a BestBuy and ask them for the speaker wire colors). Black is ground. Yellow/black is main power. Blue/white is turn on wire. If in doubt take off the door panels and look at what color wires go to the speakers.
Oct 17, 2008 | 1997 Jeep Grand Cherokee
Dual Xr4115 Mechless Digital Media Receiver 200w Logo
27 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
