Question about Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher keeps filling and overflows - Bosch 23 in. SHU33A Built-In Dishwasher
  • 1003 Answers
SOURCE: dishwasher fills with dirty water after finish
CHECK TIMER AND WATER OULET SOLENOID
Posted on Jan 18, 2008
fphandyworks
  • 56 Answers
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Posted on Jan 05, 2009
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
blackdove595
SOURCE: My Bosch dishwasher keeps back filling from the sink or garburator.. Is there a p-trap in it?
there is a p - trap sort of, your drain hose is meant to work as one, when properly installed the hose will have a hole drilled for it to come ththat is slightly higher than the drain of the sink
Posted on Jun 22, 2012
  • 9 Answers
SOURCE: dishwasher keeps running
Open up the door, get out the control unit. Pry open the unit's plastic case and look at the board. Burnt spot? If so, the heater circuit burnt out (happens a lot on Bosches) and the control is waiting for the water temp to rise, but of course it dosn't. Thus- long wash times.
Posted on Sep 19, 2012
I have a Bosch dishwasher with a E15 error. This is triggered when the basin overflows due to the water not turning off during the fill cycle, overfilling the basin. E15 turns off the water filling.
There must be a bad switch on the water level float; if it were the valve, turning off the valve via the overflow switch wouldn't stop it either.
Apr 14, 2018 | Bosch Dishwashers
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Dishwasher keeps filling
1) test the inlet valve for defective or pen
2) test the overflow siwtch for open or defective see the diagram
God bless you
Jun 18, 2012 | Bosch 24 in. SHV55M03GB Built-In...
Bosch dishwasher not completing its cycle
Sounds to me like you have a problem with with the overflow switch or float. To access the switch or float you must pull d/w out and remove the left side panel(as you face the d/w).
Mar 29, 2010 | Bosch Dishwashers
Water keeps filling after shutting off machine. Overflows onto the floor. Please help!
Most of the time the problem is just the opposite of yours and the dishwasher will not fill...
This tip is about the dishwasher not filling, but the problem is still the same, only your soleniod valve has dirt under the plunger and it will not shut off. This tip will help you find it and help you to replace it.
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
Heatman101
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 23 in. SHU33A Built-In Dishwasher Logo
85 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
