Question about Sharp HT SL75 - 2.1-channel speaker system - 200 Watt - HT-SL75
My sharp sound bar makes a static noise when running through my Sony Bravia tv
Static noise when Sony Bravia turns it on.
SOURCE: Static 'white' sound
Good day.
Try to remove the cover of your unit and clean the tube with a dry cloth. try to look for the anode cap. the one tht is connected to your tube if there are holes in it. This causes the problem.
response is highly appreciated,
chris
Posted on Mar 29, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
tehnik_bdg
  • 91 Answers
SOURCE: sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Posted on Mar 13, 2009
  • 11800 Answers
SOURCE: sharp lc-19sb225u tv turns on with a "white noise"
The blue screen means the processor of the tv no longer finishes the loading of the firmware - hardware fault, either the chip that stores the firmware or the processor have failed.
Since the chips are soldered on the mainboard and cannot be removed separately that means that the entire mainboard will have to be replaced. This is it
http://www.partstore.com/Part/Sharp/Sharp/LC19SB25U/Sharp/Sharp/DUNTKE352FM02/New.aspx
Now you must decide if it's worth paying $400 for a replacement board or it's better just to buy a new tv - i'm for the second option.
Posted on May 17, 2011
SD Tech
  • 14553 Answers
SOURCE: sound and just a Static picture when playing a VCR tape on a Sharp 13vt-N100
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
Posted on Oct 15, 2012
O tried to conect the Sony Bravia XBR 55 on internet and it apeares and now anything WORK
your ethernet cable is home made ??
you connect it to a switch or router??
try to define manualy ip adress (static ip) on the router antd tv
my sharp tv work lot better with manual setting
Nov 24, 2012 | Televison & Video
Sony google tv makes sizzling sound
Even after switch off, there can be some discharge of static charges present in and around TV, hot plastic parts can contract and make some noise. Some sets have the cooling fan run for a few seconds more to reach a particular temp, before it is turned off. Just try switching off the power outlet, and removing the plug and see.
Aug 19, 2012 | Sony Google TV NSX-32GT1 32 in. LCD HDTV
Static when i am watching cable tv.
make sure you have a nice clean cable signal. if it's fuzzy that may be causing the static. also, if you have a cable box, check the audio settings for it.
Apr 05, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony KDS-50A2000 no audio
check you sound option in sound settings menu sound settings region ie i or b or auto mike shure u on i
Mar 28, 2009 | Sony KDS-50A2000 50" HDTV
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Static noise from car stereo
change youre speakers they are blown if they are making staticy sounds i have recently chnged my speaker cuz of the static and it was kuz they were blown
thats all i can think about
hope it works
Oct 28, 2008 | iLO XM-MP3-CD Car Stereo
Humming during cd playing only.
Try turning down the volume on whatever you are playing the CD on, this sounds like an overdriven amp...too much signal for the TV to handle.
Nov 03, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sharp HT SL75 - 2.1-channel speaker system - 200 Watt - HT-SL75 Logo
141 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
