Question about Crosley Radio Cr2405C-Pa Director Cd Recorder
How to make sound come from my crosley cr2405c to my technics 4500 speakers
Just hooked up my Technics 4500 speakrs to my Crosley using rca cables.I had to cut tthe ends off to make it fit into the ports on the back of the speakers, but did not cut cable for red and white audio-out ends for back of unit. No sound coming out of speakers, but i notice a drop in sound from the Crosley when the unit is on, whether in phono mode, am-fm mode, or cd mode. Sound is only coming from the Crosley unit. What am i doing wrong. My speakers are 75 watts each. Maybe i have to use bigger wire (like Monster cable).Hope you can help me. Forget to mention, the colors on the back of the speakers are red and black. Thanks.
fridgetech
  • 473 Answers
SOURCE: Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Oct 27, 2007
  • 1894 Answers
SOURCE: Oven doesn't work
http://www.repairfaq.org/sam/micfaq.htm
see if this site is helpful for you
Posted on Dec 25, 2007
djnick989
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
cosatto
  • 29 Answers
SOURCE: lost manual for Crosley self cleaning oven-HELP
Copy the below link into your browser and contact Customer Services, they should be able to email one to you for your model
http://www.crosley.com/service.do
Posted on Dec 11, 2008
SOURCE: Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Posted on Jan 13, 2009
I just purchaseday crosley model #2405c and when you put a cd in and push play button it does not work
Hi
You can find a manual here
http://imgserve.crosleyradio.com/manuals/CR2405C%20manual%20%20%20English_French_Spanish%202011.12.19.pdf
which may or may not help with your problem.
However you state that you have "just purchased" the machine. If this is so and particularly if the machine is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | Crosley Audio Players & Recorders
Crosley projection tv
Sounds like one is not recognizing the other, By you not being to get into the set up menu means it is not seeing your blue ray player. Are you sure they are compatible? If so then if there is another way to hook it up, like with RCA cables then try that. Also make sure that there is not more than one S-video option on it.
Mar 12, 2014 | Televison & Video
Owner Manual
http://crosleydirectdpd.com/product-documents/CR246_Manual.pdf
Dec 09, 2013 | Crosley CR2405C-PA Director 3 Speed...
Crosley turntable on my record player is unbalanced does anyone know how to fix it
Sorry Regina but it sounds to me like you need to ditch the Crosley & step up to a SL 1200 model.
Aug 28, 2013 | Technics SL-BD22 Turntable
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Crosley Radio Cr2405C-Pa Director Cd Recorder Logo
54 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
