Dvd drive not working
I have a dv2401tu and earlier also the problem was comming so i got it exchanged and now also the problem has started in the new drive.the drive ejects out and the green light is also shown but the cd doesnot run What do i do
My cd-rom is missing in my computer system
Hello, Please you will fit the sata/pata cable tightly in your cd/dvd RW
If it will face same problem install a new cable if you have spare cable.
Same as before
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
It could be a problem with the lens, you should try cleaningthe lens, it's already gone bad there is no harm in trying
If it doesn't work, you can either replace the lens or purchase a new DVD/CDdrive Hope it will help you Don't forget to vote me
Dec 24, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
I have cobo drive, drive can read and write DVD's but not CD's
Hi there. You may need to re-install your drives.
Open Device Manager, click the + sign next to DVD/CD-ROM drives. Right-click on the drive and choose Uninstall Driver. Shut down your system, and restart. When Windows starts it will detect the new hardware and install the software for it.
Also, try uninstalling your burning software, restart, and re-install. It may be that the software has got corrupt.
Hope they work, and let me know if they do or don't.
Thank you
Tim
Dec 08, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
What file extension is associated with Microsoft Outlooks offline file?
  • Outlook data files (.pst)
  • Offline Folders file (.ost)
  • Personal Address Book (.pab)
  • Offline Address Books (.oab)
  • Command bar and menu customizations (.dat)
  • Navigation Pane settings (.xml)
  • Registered Microsoft Exchange extensions (.dat)
  • Outlook contacts nicknames (.nk2)
  • Rules (.rwz)
Aug 19, 2008 | Computers & Internet
Sound driver for dv2401tu laptop
Best tip is this:
make sure you didnot press "mute" on your laptop (this is often a small button or switch) or set your laptop volume to zero. Also check the volume settings in windows itself for volumes set to 0 or mute.
If all OK, download and install this file from here http://www.brothersoft.com/everest-home-edition-61488.html
it will tell you exactly all details about your laptop, including your soundcard details and most probably will give you a direct link to it's manufacturer. There you can mostly download drivers.
Please be so kind to let me know if this solved or helped.
Aug 18, 2008 | Compaq Presario 700 470024-192 Notebook
I got a new computer and downloaded the new windows vista updates and it made is so i cant see my cd/dvd rom drive in my computer settings and it doesnt read discs.
try to do system restore, go to start search,type system restore,choose "restore computer to earlier time" choose a date before today.
Aug 03, 2008 | Computers & Internet
Dvd drive
Sounds like you purchased a SATA drive when you need a IDE drive...or vise versa. Check the box. If that's the case, just exchange the drive for the proper one.
Jun 01, 2008 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Hi there...
go to the link below
URL : http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3437763&lang=en
download the HP Quick Launch Buttons update.
they should work after you have done so... aslo u need to reeboot the laptop after that.
Apr 18, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Xbox360 - Call of Duty 4 campaign & Halo 3 wont load!! Please Help!
Definitely, try exchanging the hard drive, as it could be that it is corrupt, also try clearing the cache on the drive by following the directions on Microsoft's website, under the solutions for the system freeze ups. If this does not fix the problem, then you definitely want to get a refund for the console.
Apr 11, 2008 | Microsoft Xbox 360 Console
Flashdrive detected but not working properly
Is it windows 98 you are using?
If so this might help out
http://www.technical-assistance.co.uk/kb/usbmsd98.php
Dec 25, 2007 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
