Question about Dimplex Heating & Cooling
DOC ID 255K656-61-8367R replacement
Remote control unit. The unit I have is about 7 years old. it is a plugin unit not the built in unit
hapndnvegas
  • 35 Answers
SOURCE: air conditioning unit remote control problem
when something is broke you can never break it worse so dig in and look for a stuck button or broken piece of plastic lodged in between the buttons or
you may want to go to: harmony web site and see if your model of a/c is supported these remotes are rather expensive us$129-$499 but much less than replacing the A/C and can control 225,000 devices made by 5000 different manufacturers just about any device under the sun. on the website under device choose home automation then climate control your brand then model number to see if your A/C is there. If you decide to go this route I would reccomend to check all the other devices you have also.
Posted on Apr 14, 2008
cactustaxi
  • 8 Answers
SOURCE: unit stops working and I need to unplug unit
After 7 years of great service you should retire this system and replace it with a new unit.
Products made these days are not built for quality, that was back in the good old days, it's 2008, things are made to only last a short period of time.
Sorry I couldn't be more help, but I will only tell you the best solution for your problem and not waste your time running around trying to fix something that may cost you more than replacing the problem you already have.
Have a Great Day!!
Glenn
Posted on Jun 29, 2008
SOURCE: Samsung remote control
Hey I had exactly the same problem but fixed by removing batteries and holding one button down for a couple of mins. Strange but seems to fix!
Posted on Oct 20, 2008
SOURCE: The remote control unit RB-6a is dead.
Hello. I´, from Portugal and I have the same problem. I the control unit isn´t working. I tryed to solve the problem but no one could help me.
Posted on Aug 13, 2010
  • 14 Answers
SOURCE: Need replacement remote for Liftmaster K710 garage door opener
the 3 solutions given above are not the solution to christines question, please review her question and the solutions posted and you will find they do not meld, thank you,duane
Posted on Jun 08, 2012
Our Kreisler air conditioner is rarely used, is 7 years old and will not switch on. The batteries have been renewed on the remote. Could it be the sensor in the unit? Do I need a service man?
The first thing I would suggest it to verify that power is provided to the unit. You should get a display on the face of the indoor unit if there is power. If there is power, try turning the outdoor unit off for a few seconds and back on to reset the controller. If your unit is like I think it is, the indoor unit receives its power and control signal from the outdoor unit, then the remote utilizes a rf signal to control the system. Also try new batteries in YOUR remote.
Jan 04, 2015 | Heating & Cooling
What type of transmission is in my 2000 pontiac bonneville
Hello, this vehicle uses a HydraiMatic 4T65-E, it is a 4 speed automatic with electronic torque converter lock up
(1) SRTA Tag Location (2) Transmission ID Location (3) Hydra-Matic 4T65-E ID Tag (4) Transmission (5) Julian Date (6) Shift Built A = First Shift; B = Second Shift; C = Third Shift (7) Update Level (8) Model (9) Serial Number in Base Code 31 (10) W = Warren Plant (11) Hydra-Matic 4T65-E (12) Model Year (13) Line Built 1 = Line 1; 2 = Line 2; 3 = Line 3; 4 = Line 4 (14) SRTA Metal Tag (15) Control Number (16) Serial Number (17) Calendar Year (18) SRTA Label (19) Part Number213b684.gif
Oct 23, 2010 | 2000 Pontiac Bonneville
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Universal zenith control zen450
You can d/l a free Zenith manual (PDF) here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b8e8ed044c8bd982f885efd5f432012a&q=Zenith+ZEN100
Try these codes listed for Daewoo:
002, 102, 110, 203, 214, 221, 303, 311, 314, 403, 407, 502, 503, 505, 512, 611, 805
Good Luck!
Aug 12, 2008 | Zenith DBZN-311 Remote Control
Unit stops working and I need to unplug unit
Have a Great Day!!
Glenn
Jun 29, 2008 | Frigidaire FAC124 wall/Window Air...
No hot water
After you replaced the control did it heat?? If so replace it again.
May 27, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Air conditioning unit remote control problem
Apr 14, 2008 | Heating & Cooling
Picture quality
I think you are right about the backlight. You need to replace the backlight tube or, if you can, replace the TV. Good Luck.
Sep 13, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Heating & Cooling Logo
140 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
