Question about Home
WATER RUNS COLD
I HAVE A GROHTHERM WIRELESS HIGH PRESSURE SHOWER WHICH RUNS OFF MY COMBI BOILER SYSTEM AND WHEN THE WATER REACHES THE DESIERD TEMPRATURE IT RUNS OK FOR A WHILE THEN IT SUDDENLY RUNS COLD AND U HAVE TO WAIT 10 OR 15 SECONDS FOR IT TO HEAT BACK UP??? WHY.
  • 49 Answers
ITsounds like you still have air in your lines try bleeding lines out some times it takes a while .or your getting air in lines some where try looking at the boiler at fittings .
Posted on Feb 21, 2009
Only cold water coming from Grohtherm wireless 36023
There are multiple possibilities:
- the power to the main control could be off (seems unlikely if you can turn the water flow on and off)
- the thermal element that heats the water could be burned out (may not be a problem if this is only a mixer unit and relies on external hot water supply)
- there could be a problem with the solenoid that opens to allow hot water to flow through the unit
- there could be either no hot water getting to the unit or blockage so that hot water will not flow through to the mixer
Start by making sure there is power. Then you may need to disconnect the hot water supply (after turning it off at the source) and then check to see that hot water will flow. If you get hot water to the unit then there is something internal keeping the hot water from mixing with the cold.
Oct 28, 2014 | Grohe Home
Navien combi boiler
call in a plumber. it sounds like it is malfunctioning.
Mar 18, 2014 | Taco SR503-4 3 Zone Switching Relay
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
FYV
Feb 11, 2013 | Water Heaters
I have a bristan 8.5kw electric shower, temp fluctuated to very hot, then to very cold. Now only cold. I had a combi boiler fitted now the shower seems broken, does this have any relevance to the flu
Changing the heating system will not affect an electric shower as it is run from the cold water supply,sound like the temp thermostat has blown ,contact bristan or there website to get a replacement thermostat,telling them which model electric showrr you have.
Sep 13, 2017 | Home
Water fluctuating hot and cold on a shower run off a combi boiler
could be a number issues 1 the hot and cold water supply going to shower could be of unequeal pressure thus the fluctuating 2the heat exchanger in your boiler is conjested with debris 3 the gas bed in boiler is cross burning giving an unbalanced "heat pick up"out put !2 &3 would apply if your on a combi boiler system .if your on a conventinal system you could be pulling air from the head of the cyclinder ,
Jan 19, 2011 | Home
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Home Logo
320 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
