Question about Kenwood Dnx6190hd
I have a dnx6190hd and the front right speaker cuts out when the volume is loud
I replaced all speakers when it started cutting out. It didnt change anything
    Problem Solver:
  • 10 Answers
You probably have a speaker wire that's shorting to ground. I'd get a multimeter and test the wires going to that speaker for impedance to see if there is a connection to ground.
Posted on Jan 23, 2013
Car stereo speaker only works with volume turned way up
try the fade button, if its a 4 speaker system you have balance left and right, and fade front and rear.
Dec 21, 2011 | Clarion Car Audio & Video
Only subwoofer works at high volumes
It could be your receiver but you can try seeing if the Woofer has a input knob at the back, maybe this down, or maybe.if possible turn down the amount going to the woofer with your receiver.
Dec 27, 2007 | Kicker 02S10L74 Car Subwoofer
The system will shut off once the volume reaches a certain level. The system will not get really loud.
CHECK ALL YOUR SPEAKER CABLES YOU MAY HAVE A PINCHED OR PUNTCHURED SPEAKER CABLE. IF ALL YOUR WIRES ARE RAN ALREADY GO INTO SPEAKER SETTING GO TO SPEAKER CONF, WITH RADIO PLAYING, AND START RAISING Hz IF ITS A SPEAKER CABLE PROBLEM IT SHOULD CUT OFF WHEN UR RAISING THAT SPEAKER Hz. IF IT CUTS OFF WHILE RAISING THE Hz TAKE ONE SPEAKER CABLE STRAIT FROM RECIEVER TO THAT SPEAKER THEN TRY RAISING IT AGAIN. GOOD LUCK
Jan 09, 2011 | Onkyo TX-SR608 Receiver
Volume too loud when page is used
T7316 speaker keeps cutting out. changed phone out. same problem
Apr 19, 2010 | NorStar T7316E Corded Phone
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Speaker phone volume keeps going loud and quiet
Did the location change, a Echo from a wall or vibration from the table. It is a one way sound, someone talks and you hear. As soon as you talk it cuts out the speaker even if they are still talking and it transmitts what you say. So any noise in the room could trigger the the transmit mode even an echo from the sound being turned up too loud. The mike is on the bottom of the base and can pick up table vibration and send it into transmit mode. So the person talking cuts in and out.
AL
Jan 15, 2009 | Sony SPP IM977 Cordless Phone
ZX700.5 cutting out at 60% volume
I figured out the problem, the front right tweeter wire was pinched behind the mounting bracket. everything is now working perfectly.
Sep 22, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Intermittent Sound
I was having this same problem. I realized that the fan inside was not running so I placed a small fan over the vent in the back of the sub unit. I tried this out and it worked. I then replaced the internal fan with one i bought at radio shack for a computer and have had no problems since. Hope this helps.
May 05, 2008 | Philips HTS3440/37 System
Another question for zzedly about the speakers cutting out
So, as I see it, your system is hooked up like so:
  • Ch1 = Left speakers, front and back
  • Ch2 = Right speakers, front and back
  • Ch3 = One sub
  • Ch4 = Other sub
One thing you can try is swapping channels. Swap Ch1 with Ch3 and Ch2 with Ch4. Then see if the issue still occurs on the door speakers or do the subs suddenly cut out at loud volume. If the subs start cutting out, that means the issue is with Ch1 and Ch2. If you haven't already, check the RCA connections to Ch1 and Ch2 as well as the gain for all channels. If the gain isn't already set to about 50%, put it there.
Mar 14, 2008 | Kicker IX404 Car Audio Amplifier
Kenwood Dnx6190hd Logo
48 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
