Question about Maytag Neptune MAH9700 Front Load Washer
Diagnostic code u2 - Maytag Neptune MAH9700 Front Load Washer
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
U2-40
In the following order press # * C * the machine will be in a diagnostics mode. Then press the number 16 and follow the directions on the screen to clear a U2 fault.
Feb 01, 2011 | Sharp AR-5316 Advanced Digital Imager...
Service code U2-05? How do you fix this and do i need to call a professional?
That normally means the hard drive has failed. You can remove the hard drive and it will work except for I believe it is stapling and some other finisher feature.
What you can try is this.
Press # * C * , or as sharp calles it P * C *. The machine will enter diagnostics.
Then enter the number 16 as if making 16 copies. Then press start.
It will say something like U2 trouble clear.
Press start, then select 1 for yes and press start again. Repeat that a couple of times then press clear a few times or turn the power off then back on.
Nov 05, 2010 | Sharp MX-2300N Color Copier
Photocopier not working. Sharp AR-335 Code U2-00 Please help, Thank you
U2 is an EEPROM error. The software isnt loading correctly.
2 things to try.
1. Press P * C * or # * C *. However your machine it labeled. That will enter diagnostics. You then want to enter 16, then press enter and start. That is the simulation fault clearance for a U2. If that does not work then I would suggest removing the back cover and remove and reseating the memory chips.
After you remove and reinsert the chips,do that simulation 16 again.
Aug 11, 2010 | Sharp Office Equipment & Supplies
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
Sharp ar5316 code U2
Try reset code sim 16 in diagnostics.
Type p * c * machine will go into sim mode
type in 16 then start.
press CA
machine will turn off then back on.
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Maytag Neptune MAH9700 Front Load Washer Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
