Question about Whirlpool RF378 Electric Kitchen Range
Whirlpool electric range cooktop indicator light stays on
SOURCE: "CookTop On" light stays on
Changed switch.
Posted on Mar 24, 2009
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
  • 4 Answers
SOURCE: Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Posted on Mar 12, 2009
  • 41 Answers
SOURCE: Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
Posted on Aug 28, 2009
  • 126 Answers
SOURCE: The cooktop indicator light is still on even when
MOST SMOOTH TOP ELECTRIC STOVES THE INDICATOR LIGHT WILL STAY ON UNTIL THE BURNER COOLS OFF.IF THE BURNER IS COOLED THEN ONE OF YOUR SURFACE BURNER SWITCHES IS BAD AND WILL NEED REPLACEMENT .HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Posted on Dec 12, 2009
I have a Whirlpool Electric Range, Glass Top. The "cooktop on" light stays on even though all controls are off
The problem is going to be one or more of the on light circuits on the burner control switchs is staying on all the time even when off. To check which one(s) it is gain access to the switches and check for contunuty on the wire terminals indicated in red circles. Their are 2 style switches,one the body is black and one the body is red and i have shown where to check on each style.
The first thing to do before accessing the switches it DISCONNECT POWER to unit oldtech2332_73.jpgoldtech2332_74.jpg
Aug 28, 2011 | Whirlpool Kitchen Ranges
Cooktop on light will not shut off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Sep 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
The cooktop indicator light is still on even when all the knobs are in the Off position on my Whirlpool range model RF265LXTY
Dec 12, 2009 | Whirlpool RF265LXT Range
The cooktop indicator light on my Whirlpool range, model RF265LXTY, won't go off, all of the knobs are in the OFF position. The hot surface light is off.
most cook tops the light that maches the burner is on if sw is on . if light doesnot fo off replace that sw . if only one light for all burners you will have to fint the shorted one.. good luck mm ..
Dec 12, 2009 | Whirlpool RCC3024 Electric Cooktop
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
The cooktop on light stays on
Your indicator switch is bad on this unit. This is simple to repair. Just give us a call at 972-859-0929 and provide the model number and we'll get the correct part out to you asap. We look forward to hearing back from you soon. Have a great day!
Oct 04, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Whirlpool RF378 Electric Kitchen Range Logo
466 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
