Question about IBM ThinkPad A21m 2628 Notebook
Thinkpad A-20 will not boot
When I try to boot my A-20, I hear the sound of 2 beeps and on my screen is the message "Error 0175: Bad CRC1, stop Post task"
What do I do? this is a used laptop, i bought on ebay, I didn't pay a lot for it and I don't want to spend a fortune to fix it. Can anyone help me?
Thanks in advance,
David
    Genius:
  • IBM Master
  • 1,102 Answers
If you added new memory you need to remove it
that causes error 0175 on the thinkpad
let me know if this solved your problem
please rate me
Posted on Feb 02, 2009
ERROR 0175: bad crc1, stop post task
0175: bad crc1, stop post task ,ibm t20
Jan 16, 2011 | IBM ThinkPad T20 2647 Notebook
Does any know how to fix a CRC1 error on an IBM laptop? pls help.
if you get this for a CD/DVD disc, your disc is bad...if you get this error on your hard drive, it means your drive is failing.
try to backup your data if possible and you will need to replace and reinstall all software. if the data is critical I recommend going with Drive Savers or another reputable recovery service.
Feb 15, 2010 | IBM ThinkPad T20 Notebook
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
Post problem
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Jul 15, 2009 | IBM ThinkPad A21m 2628 Notebook
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
Did't boot
You can try replacing theCMOS battery. This may work. Afterward set the bios to default. Please let me know how you make otu.
Jan 16, 2008 | IBM ThinkPad T20 2647 Notebook
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
285 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
