Question about Sony KV-36XBR450 36" TV
SAP change with no remote
I am also getting spanish on some channels and no sound on others on my SONY Trinitron XBR 36" KV-36XBR450 and I assume it is the SAP setting but I do not have the remote for it. Is there ANY way to fix it without the remote? Or do you know where I can get a remote?
  • 398 Answers
The set is definately in the SAP mode, which will have some channels in spanish and some channels with no sound at all. You might be able to get an inexpenxive universal remote and go through the menu to return the audio setting to stereo, but if that does not work then you can order an original Sony remote by model number from Union Electronics at 800-648-6657.
Posted on Jul 08, 2007
SOURCE:
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Aug 05, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Our major channels, abc, nbc, cbs have no sound. All other channels are ok. What do we need to do?
Look for a button on the remote that said "SAP"press that button to release this modes."SAP" mode useally a tranlation to spanish languages for tv out put audio for certain channels.
Feb 13, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
KV-36XBR450 input selection problem
Go into the menu on the TV and go to the far right under setup. Select "video label" then select "program". A menu will come up listing the 7 inputs. Make sure that the input you are using for your PS3 is not set to "skip". While you're there, set any of the other outputs you're not using to "skip". Your TV/Video button will only cycle through the ones that aren't skipped. Have Fun!
Feb 01, 2009 | Sony KV-36XBR450 36" TV
Sound
SAP is short for "second audio program" and is a way to send a second audio track along with the main one. In many areas stations use SAP to provide Spanish or other language sound for movies and other programs. If you have SAP turned on you don't know it until you tune to a channel where it's being used, and then you hear the other sound. Just turn SAP off using the remote control or TV menu.
Dec 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
Nov 02, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Descripticve Dialog on SAP?
Sony usually has a button on remote....MTS maybe....push =
cycles....Main...SAP....Mono.....
SAP = second audio program...........................T.
Dec 03, 2007 | Sony KV-36XBR450 36" TV
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KV-36XBR450 36" TV Logo
499 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
