Question about IBM ThinkPad T40 2373 Notebook
I hear 2 beaps at startup
My computer will not start up and I hear 2 loud beaps
  • ted2984
    ted2984 Jan 14, 2013
    can anyone tell me what is up? This is a lady's computer that I help out and need to know what to tell her about her computer.
  • ted2984
    ted2984 Jan 16, 2013
    It ended up being a signal to let her know that her battery was no good. She can still use her laptop if she keeps it plugged into the power.
    New Friend:
  • 19 Answers
Sounds like a memory or fan problem blow out computer check fan connections remove ram and try new ram if you get stuck give me a yell i will walk you through it...
Posted on Jan 14, 2013
    New Friend:
  • 16 Answers
Ted,
please go to www.bioscentral.com, then have a database of all laptops and the beep signal interpretation out there. or you can me be the brand of laptop and the model so I check for you.
Microphone noise suspension. When pushed-to-talk I hear really loud engine noise to my headset after engine startup. Headset David Clark H3530 Ground Support Headset
When I had this on a low power transceiver used a fluorescent choke in series with the 12-volt line. Well, it worked for me.
Nov 28, 2017 | Radio Communications
RILL IS BEAPING WHEN YOU PULL THE TRIGGER
Giving 2 short beaps and 2 red leds on it blinked .
If its a EY7440 ? the control pcb must be the problem itself , but if its a brushless model then the 6 mosfets on the motor could be short circuit EY754* was oft the cause, but they have modified the motor for the new EY75** models with brushless motors .
Feb 15, 2014 | Panasonic Drills
Video will not work on ps3
It may be stuck in the opposite mode of what you are using on the TV like HDMI output or S-Video. To check this press and hold down the power button, you will hear the initial beap once and shortly followed by a double beap. After the double beap immediately remove you finger. You may have to do this once or twice to get the right beap because this is a service menu they do not want you to get into. Once this is done you will have prompts on the tv to change settings to what every output you want. Make sure you change it to the right one and you should be all set.
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
My Eee pc monitor can't power on(dark),i tried to remove HDD &RAM and returned but nothing worked help me please i need to take my classes online.
when you start your pc then any beap is hear how many beaps are there
5 beaps - processor problem
3 beaps - ram problem
continues running - ram problem
2 beaps - hdd problem
no beaps - motherboard problem
firs you clean tour ram whith eraser.the try.
Jun 07, 2010 | ASUS Eee PC 900HD Netbook
I have a dell latitude d600 that i cant hear sound out of. i only hear a beap. can anyone help?
try to perform diagnosis on the computer by pressing Fn and power. or you may try to boot comp using the drivers and utility disc and perform 32 bit diags on audio.
Mar 09, 2010 | Dell Latitude D600 Notebook
Want to format ps3 hard drive does anyone know how ??
put the ps3 into standby (thts when you see the red light) then hold the power button till yuh hear three beaps and the system turns off, then take your finger off and hold the power button again till you hear two more beaps and two quick beaps when you hear the quick beaps release your finger and put it back on thn you will be in recovery mode and there is an option where you can format your harddrive
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
When I turn on my computer it beaps loudly three times screen blk
Now is a good time to check with your dealer on the warranty, sounds like a product fault.
Oct 07, 2009 | HP Computers & Internet
Play station 3 power comes on but nothing works. You can hear that it is powered up.
It's probably not in the setting you chose for example you might be using HDMI and it might be setted for SCART, to simply change this keep hold of the power key until you hear a beap (the first one when you just press the power key) keep hold of it until you hear another beap then let go. The setting should be changed. No problem :)
Sep 30, 2009 | Sony Playstation 3 (PS3) Console
How to set start up volume control
I read another post that says that if turn on the unit and set the volume where you want it at startup, and then press in the volume knob until you hear it beep, that locks in the current volume as the startup volume. I just read this, so I haven't tried it myself yet. Good luck!
Apr 12, 2009 | Jensen VM9510 Car DVD Player
IBM ThinkPad T40 2373 Notebook Logo
32 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
