Question about Music
When I play a record the words come out perfect but the Instruments are a little slow.
  • 110 Answers
You need to be more specific here. What "record" are you playing (vinyl?) -- or do you mean "record" as in "recording?" What output device are you using? Please elaborate more so that people may help you better.
Posted on Jan 14, 2013
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Why does my mixer freeze up?
Mixer brand and model? Are you recording on a DAW? Give us more info, so we can help you. If you're recording on a DAW, try to uninstall the drivers and install again, that should work...
Nov 24, 2014 | Music
Why does my mixer take so long to select something from the menu and why does it freeze up?
Sounds like you need more ram or computer space. You didn't list what time of mixer or computer so can only answer basicly. If using a computer (which it sounds like) see how much the mixer needs andhow much space available on your hard drive. This is called a latency problem. Basicaly how long does it take for the computer to respond to commands while it is doing a task. either get a bigger hard drive and more ram or clear out some files on your computer. You can also go into settings and change the settings. You'll have to look through the manual on latency problems.
Nov 22, 2014 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Why lost my effects,music play perfect, what a reason? thanks
What piece of equipment are we talking about?
Nov 18, 2014 | Music
When i put in the blank cd i record but when played back no sound on cd.not recording
A common probllem with stand-alone CD recordders is that one MUST do a "finalize" operation before the disk will play on most CD players.
Feb 23, 2012 | Tascam CC 222MKIII Professional...
Hello, I have a new black jack interface and Sony Acid studio on my PC with Windows XP. when I plug in an instrument, I can hear it in the headphones of the Blackjack, but not in the computer speakers. but...
Look at the setups for voice and audio in the Windows control panel, "Sounds and Devices". Make sure the devices are set to the sources and destinations you want... This is not automatic and is a pain when you are going back and forth from recording and playing...
Aug 19, 2011 | Mackie Onyx Blackjack Premium 2x2 USB...
I have an Omega/Lambda/Lexicon and the vocals seemed to be delayed with the timing established by the instruments. Any ideas of what to do?
Without the configuration you are using we have little to go on. How is the system wired? Are you saying when you run instruments AND mics into this then record they do not play back together? If the instruments are MIDI types and you play back along with the vocals I would expect the MIDI instruments to be delayed a little as it takes time to transmit the note info at 31.25Kb... It takes about 1/3000 second for EACH MIDI character and note messages take three of those for a total of about 1 ms. One millisecond IS noticeable by the ear... and if you have several instruments it may take several milliseconds to service all the instruments. If you are recording ANALOG instruments the delay should be imperceptible.
Apr 26, 2011 | Lexicon Lambda 4x2x2 USB Audio Interface
There is a delay with the sound I play it but the green light is,nt in sync the same time I play its a little bit delayed.
The green light is NOT a tempo light and will not be in sync with applied audio. If you need a tempo indicator, turn on a click track in your computer or use a metronome.
Jan 31, 2011 | Lexicon Alpha Personal Recording Studio
Some keys do not play and it is a relatively new keyboard with little play. I was going to take it apart myself but I need help with that. thanks
I would recommend taking it in to be repaired. If they service Roland products they will have access to any parts it needs. It sounds like the key contacts are damaged or dirty. In either case it is not easy to disassemble the Juno because of the internal wiring. It needs to be reassembled perfectly for it to work properly and it is easy to damage something during disassembly. Hope this helps.
Oct 23, 2010 | Roland Juno-D
Hi I need English instructions for the SEGA Grand Pianist
I bought one of these great little pianos from an Ontario Canada seller, and she sent me the English instruction manual in a .pdf.  It is helpful, but not perfect - I can't figure out how to play it manually. By now you have probably figured out most of what you need to know by just playing around, but if you want the instruction manual, just email me jimkatz1@gmail.com.
Dec 14, 2008 | Music
Music Logo
20 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
