Question about ViewSonic PJ551 Multimedia Projector
Projector will not stay on and light projects bubble like images
Viewsonic projector pj551 multimedia projector. When i turn it on, it sounds like a fan or fans turn on, the lamp light is solid green while the temp light is blinking gree, image is projected for about 5 seconds then turns off, and finally temp light turns off and lamp light remains blinking green all else is shut off. In some cases when i turn the projector on the lamp and temp light turn on but in a solid amber light and then the projector shuts off. Please advise. Thank you.
SOURCE: Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
Posted on Jun 12, 2008
marked
  • 6487 Answers
SOURCE: Lamp will not turn on.
If the ventilation fan is not spinning you will really have this problem, because if the fan is not working overheating problem will arise and will lead to this problen, so you will need first to replace the ventilation fan and that should fix this problem....
Hope that helps........
Posted on Sep 23, 2008
wellss123
  • 4 Answers
SOURCE: Viewsonic PJ513DB DLP Projector projects upside down
Double check which menu item you are expecting to find the orientation. It might even be under 'image', 'settings', or its own button not in the menu, Jon.
Posted on Feb 24, 2009
mastertech48
  • 149 Answers
SOURCE: viewsonic pj551 projector lamp will not light
Without more info, I'll tell you some things to check...Make sure the power cord is still plugged in firmly. With the unit unplugged, check the lamp for damage, looseness, etc. Was the unit hot when you moved it? If it was, the lamp was more prone to damage due to the heat. Always be VERY gentle if you have to move a hot projector for any reason. Did the unit sustain any hard impact while moving? Impacts crack boards, loosen connectors, and damage lamps. Make sure the lamp door is closed completely--there is a switch on the door to prevent the projector from coming on if the door is open. Make sure you didn't press any buttons on the unit too hard while holding it during moving.
Posted on Sep 09, 2009
  • 6 Answers
SOURCE: Viewsonic PJ550 lamp
Problem 1) The projector should put out a burst of 7000-15000 volts to start the lamp, and then immediately drop down to 60-100 vlts to keep the lamp lit. It sounds like the bulb blowing took out your ballast, or the ballast going out took the bulb (uncontrolled current = overheated bulb = boom)
Problem 2) Thats not a problem at all. HID lighting uses an arc to create light, just like welding creates light. Since it uses an arc, and not the heating of metal, there is no filament to test the resistance of. All the bulb is, is a special mixture of gasses and two very durable electrodes, with a gap in between.
Posted on Dec 02, 2009
Green and yellow color with viewsonic pj551 projector
the LCD panels are failing
the price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Feb 11, 2014 | ViewSonic PJ-551 Home Theater Projector:...
My PJ551 M. Projector is blinking red for LAMP and Temp? What can the prob. be?
This always happens on hitachi projectors aswell,It is just meaning that you need to clean the air vent and reset the timer and then it should be alright.
May 07, 2010 | ViewSonic PJ551 Multimedia Projector
Ghost image in different color from main image - text appears "doubled"
Use the remote to access the menu and you'll be able to POSITION the colors horizontally and vertically .
You should be able to align with the other colors to make it sync'd.
Dec 16, 2009 | ViewSonic PJ551 Multimedia Projector
Lamp timer reset on my veiwsonic pj503d
hold the up button ( on the actual projector not the remote ) for 5 sec and then press auto
Sep 07, 2008 | ViewSonic PJ551 Multimedia Projector
Viewsonic pj551 projector lamp will not light
Aug 07, 2008 | ViewSonic PJ551 Multimedia Projector
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Yellow Image
Hi there
You could if you can get your hands on the LCD's.
BUT if you have never done this before , don't try it at all. It is not as simple as all the other parts in the unit to replace !
Apr 03, 2008 | ViewSonic PJ551 Multimedia Projector
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
ViewSonic PJ551 Multimedia Projector Logo
49 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
