Question about MotoBatt 1989-1994 suzuki lt160e quadrunner 160 cc battery
MY 1989 LT160E QUAD RUNNER IDLES BUT STALLS WHEN HIT GAS
IT IDLES FINE BUT STALLS WHEN I HIT THE GAS. CLEANED CARBERATOR, WONDERING IF I LOST SOME SPRINGS. THE ADJUSTMENT SCREWS DO NOT CHANGE RPMS.
My suzuki quad runner cranks & idles but when you give it gas-spits and sputters/YOU MASH THE STARTER BUTTON asgiving it gas/runs fine.(starter stays engaged whole time)
no
there is nothing wrong with the starter but if you keep doing what you report the stater motor will burn out
the problem is in the carburetor main jet circuit or fuel blockage to the carby
you report that it starts and idles so the electrics if fine but on acceleration it plays up which indicates that the air/fuel mixture is getting too lean
now it is time to overhaul the carby, check float level, check fuel flow from the tank( taps corrode internally and block flow)
being a quad bike it could have water in the fuel system or dirt in the filter
Jan 13, 2017 | Suzuki Cars & Trucks
2013 HD fxs blackine got hit on bike went down right side changed gas tank swapped everything over no problem at first the bike kept stalling after few mins idled fine took for ride no power2 to 3thousand...
Check the intake runners are actually sealing. HD mount the air cleaner on the right and this could cause an air leak in the induction system.
May 13, 2013 | Motorcycles
1989 ranger wants to stall going from natural to first
Yes, if it was the cat, it would run poorly throughout. Might want to have your throttle position sensor checked. Try cleaning the intake with CRC intake cleaner .
Dec 14, 2012 | 1989 Ford Ranger
I just got a 05 yamaha yfz450 le and it wants to stall went taking off no matter how much gas you give and it stalls after like 10 seconds of idle after being ridden for 10 mins, i have it running on 92...
You need to pull of tne carb and just clean it i mean on the inside Take the floot bowl off its the four scerws on the bottem see how much drit is in the bowl this will give an idia of the condition of the intake air system dirty filter or mabey split air boot Get a can of carb cleaner with the little red spray tube with it The problem sounds like the NEDDLE VALVE that is the valve thats shouts the fuel off when the floots reach there highest point and shouts the fuel off to the engine if it is not sealing the engine would be flooded with gas all the time and cause this problem So take off the carb drain the gas flip it upside down take the scrwes out of the floot bowl save the gasket remove the pin that holds the floots it slides out the neddle valve is drectely under this DON;T start bending tabs just clean the valve and valve seat now sand paper paper towel and carb cleaner then spray throught every venturey you can from the out side in to clean Then reinstall and it will work like new carberators are alway the problem good luck
Nov 13, 2010 | 2004 Yamaha YZ 450 F
Car stalls when in idle
You need a tune-up. Not a major problem, and it will fix all your problems. Please don't forget to rate this answer.
Feb 23, 2010 | 1995 Toyota Camry
My 89 toyota pickup 3.0 stalls unless i hold down the gas pedel until it gets warm then it runs fine. i changed the fuel filter and the mass air flow and checked the vaccum hoses for leaks.. Still nothing
hello. Your carberator injectors are partially gummed up. go to any auto parts store and get two cans of a product call seafoam. Follow the directions on the can regarding how much you use per gallon of gas in the tank. After you have run some seafoam through the carberator it will solve your problem.
Nov 25, 2009 | 1989 Toyota Pickup SR5
Engine light comes on when idling in heavy traffic on 1989 4 runner v6 engine
change fuel filter and add can of SEAFOAM to 1/2 tank of PREMIUM gas. I think we caught this early. take out oxy sensor and clean and re-install. This an early case of Ethanol gas syndrome. try it and get back to me.
Aug 31, 2009 | 1989 Toyota 4Runner
Suzu 500 running problem
i ended up taking the carberator off and found a piece of dirt in one of the jets, cleaned it out with break cleaner and put it back together and everything ran great.
Dec 08, 2008 | 1990 Suzuki Swift
MotoBatt 1989-1994 suzuki lt160e quadrunner 160 cc battery Logo
123 people viewed this question
Top MotoBatt Electronics - Others Experts
Robert McCall
Robert McCall
Are you a MotoBatt Electronics - Other Expert? Answer questions, earn points and help others
