Question about Frigidaire FGMV173KQ Gallery 1.7 cu. ft. Over The Range Microwave in B
Want to see diagram ofmounting bracket for over range microwave model number fgmv173kwa serial number 9g03202578
Want to see visual of the mounting bracket for Frigidaire gallery over range microwave model number fgmv173kwa serial number 9g03202578
Oven doesn't let steam out
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire range is not allowing steam to come out. If your vent is blocked it will not release the hot air or steam. Could you provide me with your model number? You can locate the serial tag (which lists your model number) on the door frame of the lower drawer. With the model number I can provide you further assistance. -Matt
Mar 15, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Replaced element on frigidaire oven and oven still not working
Good Afternoon Friend,
I understand you've recently replaced the elements on your Frigidaire oven and that it is still not working. May I have your model number please? The serial tag, which lists your model number, is normally located in the storage drawer, on the right side if you have a range. If you own a wall-oven please check the front of the oven, on the left side, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better determine what may be causing the issue at hand. Thank you! - Z
Sep 07, 2014 | Frigidaire Stove / Oven / Range Cooktop...
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
Sep 05, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
VF72824070
Hello Anonymous, that's a great question!
In order to provide you the correct cleaning instructions for your Frigidaire range, I would need your model number please. The serial tag, which lists your model number, is normally located in the storage drawer, on the right side. Thank you and I look forward to hearing from you. - Z
Aug 30, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
316065306how many watts to run this range
Hello friend, thank you for your post!
I understand that you are searching for the wattage on your Frigidaire range. In order to provide you more information I would need to have your model number. You can locate your serial tag (which lists your model number) on the outside of your cooktop base possibly on the edge or bottom under the unit. Once I have that information I can further assist you. I look forward to your response. -Matt
Aug 19, 2014 | Frigidaire 30 in. Electric Ceramic-Glass...
The microwave made a loud pop sound when starting to heat up something. Microwave continues to "appear" in working order, but does not heat anything at all. Over the range type. Model: GE Spacemaker...
Home owners should not try to repair there own microwave, you should call a professional to diagnose and repair
always unplug electricity before attempting to repair on any electrical appliance
Sep 21, 2017 | General Electric Ge Profile Profile...
Im having problems with my electric Gaffers Sattler stove. One of the burners is alwas on high when you turn it on. I cant find a serial number. Thank you for your time.
The switch that controls that burner is defective.
Pull out the lower pan drawer and look for a model number on the range cabinet.
If you can not find a model number,unplug the range,remove the switch and get a part number from the switch.
Jan 06, 2010 | Cooktops
Frigidaire FGMV173KQ Gallery 1.7 cu. ft. Over The Range Microwave in B Logo
24 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
