Question about Kenmore Kitchen Ranges
Why doesn't the middle element on triple element light up , sears says this is normal. i don't believe that
    Genius:
  • 1,669 Answers
If you are talking about the heater coils on the electric range, understand that depending on the temperature you turn it up to it will glow more red. The ends of the coil heat more by design...
Posted on Jan 14, 2013
Front right burner under stove top model 62960002603 only heats to LOW heat. It has a single, dual, triple mode setting and will not heat up to highest setting. HELP.
I looked up the model number you gave. It is a Kenmore range.The part number for that element is 7406P494-60. When you say it only heats to low, do you mean that only the center portion of the element lights up? Normally, when this occurs, it is an indication that the middle element and outer elements have a break. The problem could also be a faulty infinite switch(burner control). The part for that particular control is 7450P011-60. You will need a voltage/ohm meter to troubleshoot further. This can be a very INVOLVED repair attempt. I recommend, that if you're not comfortable disassembling your unit, call for service--this can absolutely be a tricky diagnosis and much care is needed to not damage the glass cooktop when checking the element. I hope I helped you.
Aug 31, 2015 | Kitchen Ranges
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
My Oster wafflemaker doesn't get hot! The lights are on but only gets warm
One or more of the heating elements are not activating. If you take it apart, perhaps you can do a continuity test on each element to see which is bad. I don't believe they sell element replacements so your only choice would be a new purchase or warranty.
Jan 29, 2013 | Kitchen Appliances - Others
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
Using an oven with a broken element
if it's electric the broil element also comes on when baking or using the bottom element,it comes on for even cooking when baking so whatever you're cooking will cook on top and bottom so don't use it until you buy the new element and whenever you work on the machine unplug it,also you can damage the clock assy. and that's the computer board and those can be very expensive,i've gone in,changed out the element and it still doesn't work from the element shorting out when it broke and it takes out the computer board so hopefully this doesn't happen
Nov 16, 2011 | Kitchen Ranges
The grill gets hot but doesn't brown the food?
Normally, if a grill element fails, it just stops working. So if they are working then on full power, both elements should get red hot! If this is the case, all I suggest is that you try experimenting with different heights with the grill tray. And by the way, don't shut the door when you are grilling as this shuts the grill off!
Oct 28, 2011 | Stoves 720EF Electric Double Oven
My son stuck a screwdriver in the cigarette lighter of my 2004 chevy blazer I opened the fuze box interior one the 15A fuze was fried Replaced it but still the lighter doesn 39 t work Checked th
I don't believe that the lighter has a relay in it's circuit. My best guess is that the lighter element shorted out, causing the fuse to blow. The lighter part that you pull out of the socket can be disassembled by unscrewing the knob. The element (part that glows red) can be replaced. Any auto parts store should have one.
Best regards, --W/D--
Oct 20, 2011 | Cars & Trucks
Does the ac triple pressure switch have a valve to stop freon from releasing when you change it?
No... it's just a pressure sensor switch. If the pressure is normal range, it maintains that connection... if the pressure drops below a predetermined threshold, then it sends that signal to the engine control module and the a/c control module.. if the pressure rises above a predetermined thershold, it also sends this signal to the engine control module and the a/c control module.
Conclusion: High pressure - AC doesn't operate... shuts down
Low pressure - AC doesn't operate.. . won't come on
Normal Pressure - Normal Operation
Jun 06, 2011 | 2004 Hyundai Santa Fe
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Dec 20, 2007 | Kitchen Ranges
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
