Question about Fuji FinePix A350 Digital Camera
Zoom error too
I am having trouble with the "zoom error" command also. May be a piece of sand got in the lens and jammed it. the telescoping lens will not extend, and photos cannot be taken. Any thoughts on repairing this?
  • 2 more comments
  • playerhigh Feb 17, 2008
    i keep getting zoom error message pop up when i switch my camera on
  • A350User Feb 20, 2008
    When I turn on the A350 the lens does not extend and I get a "zoom error" from the camera. I have replaced the batteries to be sure low power is not the cause.
  • Anonymous Mar 30, 2008
    telescoping lens jammed - will not extend
  • dvlshangl11 Mar 18, 2009
    i dropped my camera and everything else is fine accept the zoom lens.
    keeps saying zoom error.
    do u think these solutions will help or is is straight up broken?
If you spill any thing, like a soft drink,tea,coffee,etc. anywhere around the camera, when the lens barrel is open, it will cause it to stick when it is closed. so when it dries, you are stuck. put fresh batteries in, and with a rubber mallet, lightly tap on the face of the lens, when the camera is powering-up. do not hit it hard. after two taps, my camera lens opened up. you can clean the barrel with some wd-40, with a q-tip swab. use very sparingly. and next time, be very careful where you lay-down your camera. you never know......
Posted on Feb 06, 2009
I BOUGHT ONE OFF EBAY THAT WOULD NOT OPEN OR CLOSE ....MY REMEDY WAS TO SPRAY WD40 ON A Q TIP AND RUB IT AROUND THE TWO ZOOM BARREL TUBES..CYCLED ABOUT 30 TIMES NOW WORKS FINE..MARV
Posted on Mar 31, 2008
I had same problem caused by sand. I improved it (not fully fixed) by swiching off, adding fresh batterys, turning on and flicking the zoom in/out button up and down. If you can get the 2 part lens to extend try to clean the sides as much as possible. Made it better for me but probably a service is the best solution.
Posted on Jul 28, 2007
    Problem Solver:
  • 32 Answers
No I don think piece of sand got in lens.you need to chek the zook button if it is faulty then i think this error should diplay sangita
Posted on Jul 08, 2007
SOURCE:
My camera is displaying that I need too turn it off and turn it back on . I have done this several times,?
Fixing a Lens Error (Stuck or Jammed Lens) on a Digital Camera
(Last Update: 13 February, 2014)
If this information helps you, please pay it forward, and share this article with others who may be experiencing the same problem. Your help in sharing will be appreciated, and karma will prevail!
This has to be THE most common failure mode for a digital camera, a stuck lens, jammed lens, or a malfunctioning lens. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canon Powershot), "ACCESS" error (Sony Cybershot), "Zoom Error" (Fuji Finepix), "Lens Obstructed" (Kodak Easyshare), "lens error, restart camera" or just "lens error" (Nikon Coolpix and some other camera makers lately are using this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Note that this problem applies to ALL cameras with telescopic lens barrel (optical) zoom. With Samsung's release of the Galaxy S4 Zoom, I'm really curious to see if this will also be a issue/problem with this camera phone (and other phones with optical zoom). I predict (on June 16, 2013) that it will, as most people carry their phones in pockets and purses. If it occurs, Fix 5a would likely be the best technique to correct this problem.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
First here's a video summary of most of these fixes, and following that a detailed text description of the fixes. Recommend reading the text first (along with the reader's comments and tips section) as these provide additional tips for situations that the video does not. For example, the video focuses on repair fixes for a camera that does not have obvious damage to the lens barrel (such as from a fall). Thus it does not cover straightening the lens barrel if it is crooked, which the text does. Use the video primarily for further clarificati
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2015 | Cameras
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Kd 400z Konica Advocate errors0042 en errors400e
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
Jun 19, 2010 | Konica Revio KD-400Z Digital Camera
I have dropped my friends camera (while it was on). It hit telescope first and got jammed is there anything I can do? It is an olympus stylus 760 7.1 All-Weather. It was purchased on ebay about 6 months...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Olympus Stylus 760 Digital Camera
Says lens error restart camera yet my lens will not close
Hi, your lens has probably been damaged , usuallly by dropping or bumping , or sand or some other particle may be jamming it. Try using a piece of photo film ( exposed negative) to search for anything that may be stuck in the lens where it telescopes out. Another "fix" is to firmly bang the corner of the camera case into the palm of your hand quickly after pushing the power button.This may loosen the jam
Oct 30, 2009 | Canon PowerShot A540 Digital Camera
Lens Error
Sand is a killer to cameras. If sand becomes lodged in the lens bellows it will jam. I have never after thousands of repairs had any lasting success in trying to repair. When taking a camera around water and sand buy some sandwich bags to place camera into protects against water and sand.
Jul 01, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Lens wont move
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 17, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
Zoom lens wont close
Sounds like you broke a lens gear, or it is jammed with sand.
Nov 17, 2008 | Cameras
Fuji FinePix A350 Digital Camera Logo
216 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
