Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam wfw9500tw01 f35 code - Whirlpool Duet GHW9150P Front Load Washer
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
SOURCE: whirlpool duet washer flashes F35 model
I had a F35 error pop up, then Sud error started to occur. On the Clean machine cycle I would get a F 21 error.
On the top off the machine the is a pressure sensor that is at the rear right side at the top and has a black rubber hose in it and a set of wire that clips in. It clips to the washing machine wall. I replaced the censor for $144 Canadain. It works great now.
Use the correct soap.
I attemped to runn the machine over and over hoping it would just clean it self, with no luck.
I also opened the rear od the machine cleaned the hose and the canaster the attaches to the washer that leads to the pressure sensor, this also did not help.
I opened the bottom front of the washer and cleaned out the pump resevour ( use a bag to catch the water) I found a few things in there like money and various pocket stuff.
I even flushed nthe sensor out with a ink loader seringe in hope to clean out the sensor. This only made the sensor show the Sud error emediately as the water enter the machine.
Be all, end all was a new pressure sensor fixed all the errors.
Posted on Mar 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code washing is delayed wil wash half the clothes
ginko
  • 19396 Answers
SOURCE: My Whirlpool Duet Steam Washer, Model# WFW9500TW01
Hi.
Usually the code is fixed cleaning the hose connected to the pressure switch or replacing the pressure switch.
SUDS and F35 means that an excess of detergent has been detected by the pressure switch. If the problem happens even when there is no effective detergent blockage, then the pressure switch is responsible.
The pressure switch is located inside the cabinet in the top part of the appliance, in the back right corner and it is part nr.20 in diagram below. To access it there are three screw at the back-top side of the washer. Undo the screws and remove the top.Disconnect power before starting and observe safety prescriptions.
Here the diagram. Click on the picture to enlarge:
Here the replacement part:Water Level Pressure Switch
Posted on Sep 12, 2011
Whirlpool duet steam WFW9600TW00 code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Steam Washer - White
Sep 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Wfw9500tw01 model suds and then f-35
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
Model: wfw9500tw01 f35 error
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Steam washer (WFW9600TW) flashes F35 shortly after the cycle starts and then turns itself off.
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine model wfw9500tw01
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
