Question about Tools & Hardware - Others
Senco SLP20 shoots blanks
The gun fires but the pin doesn't grab the top brad in the clip. The pin just makes a dent in the wood, as if there were no nails loaded. The problem used to happen rarely and has grown to be almost constant. Happens with a variety of brad sizes. The spring in the clip is working fine, as you can feel the increasing pressure of the nails as you close the clip.
  • Michael Lowery Jun 23, 2013
    I found the SLP20 will fire one nail then won't feed, unless you use Senco staples. I can't get them in my area. If you put a micrometer on the nail head width, you see Senco nails are 74 and other brands are 76 or better. Find a bench grinder or fine grinding device and make a couple of light passes on either side of the nail row heads. Modify any brand and they should feed through the SPL20 with no problems. Michael, Rome, ga
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Posted on Jan 01, 2009
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
Senco a200bn not working
Senco sold the A200BN under the Accuset line around 1999. They were not on the market for long because it was not a reliable tool and now parts are extremely hard to find. If you go to www.toolpartsdirect.com and search by model number they have a good breakdown of the tool and a few parts available. If you're having feeding problems I'd look at the rail, feeder shoe and feeder springs for bends, breaks or blockages.
Apr 15, 2012 | Senco Fastening Systems No.43OOO1N SLP20...
Senco nail gun sfn30 is only firing every second nail in
You have damaged o-rings in the gun. Remove the head cap & valve assembly, remove the ring on top of the cylinder, remove the cylinder & piston. The cylinder is in tight so work it out carefully. Check the condition of the following: a split flat ring with a rubber o-ring under it on the top of the piston and two o-rings on the outside of the cylinder. If these are damaged air will leak around the piston instead of pushing it back up. The inside of the gun should be clean with a light coat of oil on everything if you are oiling it properly before use. Dirt in the gun means the gun is being laid on the ground without the air hose attached. Dry innards means no or not enough oil is being put in the gun before use. Oil pooled in the bottom of the gun means too much oil is being used. Senco doesn't make a rebuild kit for this gun, you'll have to go to the Senco website http://www.senco.com/ or other website like http://www.ereplacementparts.com to get a parts breakdown of your gun and order the o-rings (any part beginning with LB) individually. If you replace one, replace all of them and grease them up liberally when reassembling the gun.
Jan 29, 2012 | Senco Tools & Hardware - Others
SLP 20 Leaks air from top and I Just replaced the chamber and o Rings.
The slp20 uses a firing valve part # ba0119 black plastic w/rubber boots. This valve is what prevents air from leaking thru top of gun. If pin hole has developed, or oring # lb0012 is not in place under the firing valve or if the retainer # bf0149 does not fit snugly on cylinder or has cracks, the gun will leak. Assuming oring is in place and retainer is good, suspect firing valve. Good luck
Mar 26, 2011 | Senco Fastening Systems No.43OOO1N SLP20...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
The driver doesn't return after firing. it is a porter cable brad nailer BN200
This is pretty common with brad nailers
Remove the brads from your gun - disconnect from the air supply
On the front of your gun is a latch - open it
Check the sliding surface for build up of dirt or small pieces of metal from the brads.
Once clean polish the surface with a fine steel wool or a small brass brush
Reassemble with a drop of machine oil on the sliding surface
Oil your gun as you normally would
Using a piece of soft wood dry fire the gun 10 or so times to ensure that the dents it is making in the wood are all pretty even
Reload and nail something
Mar 08, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Slp20
By replace I take you mean o rings? If so I would look to see if one got pinched upon reassenbly. If not let me know exactly what you replaced and I will look at a breakdown and see if I can help.
Jan 25, 2009 | Senco Fastening Systems No.43OOO1N SLP20...
Senco SLP20 not working
Senco makes a line of nailers including the slp20 that use a firing valve (part # ba0119) that fires piston when trigger is depressed. These guns do not use oil because the oil will swell the rubber parts in the valve. When the rubber swells and tears slightly, symptoms that you describe will develop. Also remove the cylinder and look for cracks and make sure that the lower oring (LB0030) is in place and that tiny vent holes are clean. The lower oring is the checkvalve and causes the piston to retract. Use only the slightest bit of silicone lube on orings. Parts are available at www.toolpartsdirect.com. Good Luck
Jan 22, 2009 | Senco Fastening Systems No.43OOO1N SLP20...
My senco finishpro 18 won't shoot
the seal on the piston requires replacement all seals are o rings and can be supplied by your local bearing stockists also check that the blade is straight and has no burrs
Nov 26, 2008 | Senco FP18 FinishPro 18 - Gauge Brad...
Tools & Hardware - Others Logo
62 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
