Question about Broan-NuTone N-763RLN Combination Light Fan Exhaust Fan
There is no suction from the fan on my 763rl. What is the problem?
There is no suction. The fan is spinning but there is no suction. The light is working but again there is no suction.
    Sergeant:
  • 311 Answers
The exhaust may be plugged with leaves or branches on the out side, where it exits your house.
Posted on Jan 19, 2013
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
The touchpad gets hot after 10-15 minutes.
Listen for the fan - if you don't hear it spinning then the fan maybe bad. Check around the sides for the airflow ducts and feel the air suction or exhaust.
Nov 09, 2010 | Dell Inspiron 1525 Notebook
My kirby g5 is not picking up, there is no blockage, but suction has dropped significantly, what could be the problem?
Not to question your description of the problem, but are you sure the suction has dropped? Kirbys don't usually lose suction unless there is a mechanical or electrical problem. When you turn the machine on does it fill with air and expand? If so, then you probably have enough suction. If the bag doesn't fill and expand and your machine is extremely noisy then the fan may be broken and need to be replaced. If you see excessive sparking near the bottom of the handle then you may have a motor problem like stuck or too short carbon brushes or a bad armature. On rare occasions, with Kirby owners who live close to a beach area and vacuum large amounts of sand, the sand actually wears down the vanes of the fan enough to make it useless. To check the fan; first unplug your Kirby from the electrical outlet, remove the brush roll nozzle, slowly spin the fan/belt pulley while observing the surface of the fan, look for cracks or breaks. The fan vanes should be about 3/4 of an inch deep.
If none of the above fixes your problem, look at the brush roll and belt. If your belt has not been changed in the last 12 months, install a new belt. If this is the original brush roll, install a new brush roll.
May 18, 2010 | Kirby G5 Bagged Upright Vacuum
Poor suction
This vaccuum has a Fan Blade inside connected to the motor that spins to create the suction you feel. After a few years of use (and misuse) the blades on this (plastic) fan will be broken off, thus damaging the unit. These Fans are replaceable if you can find where you can purchase a new one. Now, if you have any knowledge of repairs at all, it's not that hard to replace to fix. If you don't feel capable of this though, I suggest you refer to someone more qualified to do this repair.
Oct 10, 2009 | Vacuums
My Bissell TurboForce Bagless Turbo Brush doesn't work
clean the filters..on atop the dustbin, inside the dustbin bottom..and over the fan below..if not sqeaky clean you loose suction
Sep 07, 2009 | Vacuums
The motor is running, the roller brush spinning rubber smell
Sounds like the main suction pipe is blocked.
Unplug, and in good light - see if you can see any obstructions in the pipe from the prush area to the bag (in a bagless vacuum) or to the fan in a bag model.
Aug 04, 2009 | Vacuums
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Power head on epic 6500 does not work, is there a belt?
This is a bot of a blind guess, I don't know the model. But most power head cleaners I have worked on use the suction of the vaccuum to spin a turbo fan in the head (like blowing a child's windmill). The head not spinning is usually because there's not enough **** to spin the turbo fan. Check for:
Gummed up brush bearings (dirt or damp) making the brush harder to turn than it should be.
Poor suction caused by a blocked or partially blocked pipe.
An obstruction that is tactchin the beater or the turbo fan.
Blocked filters on the cleaner, reducing the **** and thereby not providing enough vaccuum to spin the beater.
Jan 18, 2009 | Electrolux Epic 6500 Vacuum
Kirby G6 without suction
you probably have a clog in the feed tube going from vacuum head to the bag try removing bag and check for clog there hope this helps
Aug 20, 2008 | Kirby G6 Bagged Upright Vacuum
Broan-NuTone N-763RLN Combination Light Fan Exhaust Fan Logo
61 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
