This thing wont program right to use remote. It keeps saying line 1 when you use remote. Sometimes it wont respond or even power up. What do i do. Its fairly new.
    Genius:
  • 1,669 Answers
If it is under warrantee, bring it back or send it back...it's not for you to mess around with!
Posted on Jan 14, 2013
I followed the instructions (Brookstone giant remote and Samsung TV) above for manual programming and it worked.... that is it went on. But the volume control doesn't respond and I can't change the...
sometimes there is more than one code that will work for your tv even though its not the right one. Try all the samsung codes even if you found one that worked, try the rest.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Feb 09, 2011 | Brookstone 538744 Remote Control
My tv turns off and on and sometimes wont respond to the button or remote. I've taken the back off and all capacitors look good. Some people say motherboard some say power supply. Any ideas?
Tv turn on.Power LED indication light on solid green,have picture.Only problems it wouldn't respond to any controls wright?It the Tuner signal motherboard board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 17, 2010 | Samsung LN32C450 32 in TV
My remote says no antenna. can not arm alarm.
REPROGRAM YOUR REMOTES USING THIS PROCEDURE:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
Jul 06, 2010 | C3 RS6652W (NEW with 1 LCD Transmitters)...
Cant us the remote dont know how to accss the
These are the steps on how to program your Universal Remote Control to your device even without the list of code.
1. Manually turn ON your device.
2. Press and "HOLD" CODE SEARCH
3. Press and release the device button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the device turns off, press and release ENTER.
7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 14, 2010 | RCA Universal Remote Control
The unit doesn't respond to the remote. If I unplug it, it seems to reset. Sometimes it will not even respond to the power button on the unit itself.
9 times out of ten its the remote being the issue here try replacing the batteries ir cleaning the front where the remote sensor is that may help it. If you try-ed resetting the remote and still have issues this the remote will need to be replaced.
Thanks and do please click the accept button for my efforts.
Jan 02, 2010 | Nakamichi SoundSpace 5 Shelf System
I have a Panasonic DVD/VCR TV. The remote control works intermittently. Sometimes I can control the volume and DVD/VCR using the remote and sometimes the TV does not respond to the remote. I spoke with...
Do you still have the instruction booklet for the Tv? Find the remote codes and try re-programming the remote. If this still happens try programming an after market universal remote. Hope this helps.
Sep 12, 2009 | Panasonic Televison & Video
My 32" Toshiba LCD HDTV keeps freezing on the same channel and when I try to change the channel or input selection, it doesn't respond(to the remote or directly on the TV.) The only thing that works is...
These problems are normally caused by the TV station.
1. Call the TV station responsible and ask for the network engineer.
2. Tell him the Day, Time, Channel, Program, basically every little detail about the problem.
3. The station will normally check it and fix it.
Also, contact Toshiba and tell them. Really this is part of the DTV Transition thing. Many stations are reconfiguring and settin up equipment. They sometimes make mistakes. Don't worry much about it unless it continues for more than a week. If you like the station, I would call right away.
May 25, 2009 | Televison & Video
Samsung tv
If the set has a power button, try turning it on with that.  I suspect it won't respond to that either and the problem is really with the TV itself.
If it does have a power button and the set reacts the same, then either the power supply in the set or a circuit it services has failed. You didn't list the TV model number so we don't have enough information to even start with.
One last thing you can try is to pull the AC plug and let it sit overnight; sometimes circuits can 'lock up' and will respond again if allowed to sit and all its internals go to zero for a while.
Sep 22, 2008 | Samsung Remote Control
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
Mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Jan 19, 2006 | Zenith MBR3447 Remote Control
Televison & Video Logo
Top Televison & Video Experts
