Question about Panasonic Technics Sa-gx690 Av Control Stereo Receiver/ Amp/ Amplifier 100 W Surround
Amp keep's sating overload
  • 1 more comment
  • Beryl Britt Jan 15, 2013
    Hi , My name is Dean, You wanted more information on my Amp. It is a Technich's sa-gx470 class h+ and all i can tell you is when I turn my stero on it will start clicking and lose the sound then come back on and then go through the same thing again. The clicking sounds like it is coming from the right side where there are four round fuse like cyclinder's. . It look's fairly clean inside and one of the fuse like canister's says 85 degree c on the top of it. If you can't help me maybe you could tell me who icould take it to. Thank You
  • Beryl Britt Jan 18, 2013
    I did disconect all external componut's and that didn't help. And also it is a sa-gx470not the outher one you are refering to. Thank You.
  • satcalvi
    satcalvi Jan 18, 2013
    Hmm, I didn't refer to any specific amp. Did you remove ALL the cables and see if it stays on? If it still shuts off, it is an internal problem and you need to have it repaired. If not then follow my original suggestion.
    Problem Solver:
  • 17 Answers
Have you tried disconnecting all the speakers and inputs and turn it on?
If it still shuts off you have an internal problem, if it stays on, connect one item at a time until it shuts off and that is the problem.
Posted on Jan 16, 2013
Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Aug 22, 2012 | Plumbing
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Headlights on my century class freightliner base model cst120 overloads on my headlights of my...
amp = watt / volt
amps = 600W / 12V = 50A
You are running about 600 wats
Oct 29, 2017 | Cars & Trucks
What is this used for
Perfect for Home, Shop & Hobbyist. * Input: 115V AC, 60Hz, 270 Watts. * Output: 13.8V DC. * 12 AMP Constant/14 AMP Surge. * Powers Cellular Phones,12V DC CB Radios, Scanners, HAM Radios, Autosound Systems. * Screw Terminal Connectors. * Electronic Overload Protection w/ Auto Reset. * Short Circuit & Thermal Protection. * Fuse Protected. * LED Condition Indicators. * Heavy Duty Cabinet & Heatsink w/Anti-Skid Rubber Feet. * Dimensions:7.87'L x 7.16'W x 4.72'H
Feb 17, 2012 | Pyramid PS14KX 270-Watt Power Supply
Why the fuse blow
Possible causes...
1. Your power wires into the amp are reversed
2. Something in the amp is shorted
3. Your sub is shorted
4. Your sub is incorrectly hooked up and is showing a lower load than the amp can handle.
Check resistance on speakers. And make sure your not overloading amp with incorrect ohm load for speakers.. You raise and lower speaker ohms by wiring them in a series or parallel. It's a good idea to make sure your power cable sizes are correct and can handle the voltage & amperage.
Nov 16, 2011 | Car Audio & Video
Stator and reg keep going out
If your stator and regulator keep failing, it's generally caused by an overload. Have you added any extra lights or electrical gear to your bike? If so, you may be overloading your charging system. If your bike is equipped with a 42 amp system and when you've got all your stuff running it's drawing 38 amps, your charging system is working to almost capacity to provide the current that is being demanded. This causes the components to run hot and they fail. My advice to analyze your current needs on the bike and look for a system with higher output capacity or take some of the current demanding equipment off the bike. Cycle Electrics builds a "three phase" alternator kit that works well. I've installed several of them and never had a problem. http://www.cycleelectricinc.com/
Good Luck
Steve
Jul 16, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Led's don't power and there seems to be a pulsing coming from inside the unit, even after it's powered off the pulsing continues but gets more and more faint. This sub worked fine a day ago,...
Likely the amp blew and the power supply is being overloaded and keeps trying to power on but finds an overload and continues as the power goes away. This is NOT a DIY unless your are electronically adept.
Jul 14, 2011 | Mackie SRM 1801
Won't play keeps saying overload
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and
operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by
the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient
ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan
(if equipped) is running as designed (some only operate on demand). Clean dust and debris
from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection
cycles in their lives so continuously resetting or cycling their power without addressing the
cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections
and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not
come up the problem is internal and should be left to an experienced and competent hands-on
tech.
Check for loose speaker connections at the speaker as another possible root cause for
intermittent shutdown.
Jul 09, 2011 | JVC RX-7000V Receiver
Sharp ar 122 ccd trouble how to repaire
Sharp AR-122 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 23, 2009 | Sharp Office Equipment & Supplies
Panasonic Technics Sa-gx690 Av Control Stereo Receiver/ Amp/ Amplifier 100 W Surround Logo
166 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
