Red drum light comes on when trying to make a copy.
  • 1,326 Answers
It means you have to replace the drum unit. I'd like to tell you what to do, but do not know what kind of copier you have? Good Luck
Posted on Jan 14, 2013
Red drum light on copier not working
Are you talking about the light inside near the drum (the laser) or the maintenance light?
Jan 13, 2013 | Sharp AL 1631 Copier
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
Will not print out a complete copy, gives red light signal when trying to copy, and gives a "dirty" copy. we need to unplug, and/or hit the reset button everytime we use it, and occassionally it...
  1. you have to check the counter, if you get a bad copy quality it can be the cause of opc drum life end.
  2. if you are using a new OPC drum, you need to clean the copier, it must be doing by a technician,
  3. when you get the red light signal: look at the LCD and read the error message displayed. it can gives you an idea about the problem. you post your problem again on Fixya or just live a comment for this solution i will answer you.
Dec 27, 2010 | Canon PC-D340 Black and White Copier
The red drum light is blinking and it will not make copies
HI drum is reach for end of life thats why drum light is blinking you shuld have to replace the drum or just reset the drum counter to run your machine for another life .
thanks
May 11, 2010 | Sharp AL 1631 Copier
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Canon np6012f, all lights work, no trouble lights are on, yet copies come out blank, no image at all. Suggestions? Copies are coming out blank. Toner is not the problem, drum roll is not indicated.
How do you do. The Problem clear. This simply, back two questions. The First. The Scene is copied with transverse white band? Zdelayte check. She consists in following. You Do the copy and switch off the main by breaker just when sheet under drum. Afterwards remoove the drum. or see on it. If on drum scene by parts no, well test for newspaper, that question locked. Exactly, your бврабан came out of building, more exactly light on bright light, sun.Change the drum. Good luck you!
Sep 14, 2009 | Office Equipment & Supplies
Minolta CF910 Copier
CF910 is Minolta first generation color copier, does any color like green or blue color have the same problem, there will not be any error message to change image units. only toner. The machine has only one drum, and each color gets a chance to place its color on the drum. Paper is held by the big plastic drum next to the drum. You should think about having a service technician come out and look at it.
Jun 30, 2009 | Konica Minolta DiALTA CF910 Copier
Replacing drum unit on copier: Sharp SF 2114
Well, if the light under the glass doesn't come on, that means that black copies can hapen. Nothing to do with the drum or drum unit. Either the lamp burnt or the protecting fuse is blown. If you take out the glass, you can mouve the carriage with the mirrors to the right and you can see the exposure lamp. If it has dark ( like silver) bands on it, the lamp is burnt and its brightness will not be enough to make a copy. CHANGE THE LAMP. If the lamp is ok check the thermic fuse wich is in touch with the lamp carriage, and normaly it burns when taking a lot of copies in one go. The drum is a red cilinder that is in drum unit next to the developer unit where you put the toner. If you open the ma chine you can see it about the midle just above the transfer corona. If you don't get it right i can explain how to change the drum. GOOD LUCK.
Nov 02, 2008 | Office Equipment & Supplies
Drum light
You need to reset the drum count. Open the toner door. Hold the "Go" key until all 4 lights light up. Let go of the button and close the door. That should reset the drum count and stop the blinking.
Jun 11, 2008 | Brother HL 5140 Laser Printer
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
12 people viewed this question
k24674
