Question about Refrigerators
Frigidaire model FFHT2126 21cuft top mounted freezer will not keep constant cold temrperature.
Model FFHT2126LW2 purchsed 9/2011. Top mounted freezer thawed out food unexpectidly, and now will not hold a constant temperature. turned down thrermostat to no avail. Fridge stays at 40 degrees, but freezer moves between -5 and 30 degrees.
murdozzz2
  • 75 Answers
SOURCE: Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Posted on Dec 11, 2007
22yooper
  • 828 Answers
SOURCE: Refridgerator temperature
I think it may be a defrost system problem. If you have frost on the back wall the problem is related to the defrost timer or defrost heaters or thermostat.
Also check the condenser for dust. If plugged with dust the system can not get rid of the heat. If dust is present clean it out completely.
Remove the toe plate under the refrigerator door to check the condenser.
Posted on May 24, 2008
huuum
  • 750 Answers
SOURCE: Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Posted on Oct 03, 2008
  • 118 Answers
SOURCE: admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Posted on Jan 31, 2009
  • 420 Answers
SOURCE: Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
Posted on May 26, 2009
I have top freezer refrigerator that is not getting cold in the refrigerator area. The freezer is cold but the refrigerator is not getting very cold. The model # FRT17G4BW7.
There is a damper between the 2 sections that opens and closes based on the temp of the fridge.
One of the following could be the problem...
** Thermostat defective.
** Damper solenoid defective.
** Damper door frozen shut.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2010 | Frigidaire 16.5 Cu. Ft. Top-Mount...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Freezer cold- Fridge Not, Loud Noise
that is the damper door malfunctioning this open to allow cold air into the fridge compartment the damper needs to be replaced
Sep 20, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
Freezer not getting cold on frigidaire top mount refrigerator model FRT21LR7A.
If you give the make and model number someone may be able to direct you to a place that will have it.
May 23, 2008 | Refrigerators
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Frigidaire Model # FRT15G5AWO Top Freezer Refrigerator
frigidaire makes a garage kit to operate refrigirators at lower temps. the kit is about 18.00 dollars, it is avaliable from electrolux,1800-599-7569
Feb 16, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
