Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Lcd reqds 5y ce - Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
  • Official Brand Answer
  • 4,342 Answers
Hi John Dirksen- Could the error code possibly be SY CE? If so, it typically means that the unit has detected a communication error at power up. A professional will need to check the wiring between the main control board and user interface. Depending on the diagnoses from the professional either part may need replacing.
Posted on Jan 15, 2013
Code on door of French door reads error message 5y ce. sounds like it is still running but no light inside or ice maker not working.
Thank you for your post, Carol!
I understand that your Frigidaire refrigerator is displaying an error code of "5Y CE". However it appears that "5Y CE" is an invalid error code. I have noticed the code of "SY CE" and that means there is a communication error at power up. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue it could be possible that there is an issue with your main control board, wiring harness, or user interface board. I would then suggest having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
May 19, 2015 | Frigidaire Refrigerators
WHEN IT DISPLAYS 5Y CE WHAT DOES THAT MEAN?
The SY CE error indicates that the user interface (key #2) and the main control board (key #38) are not communicating properly. You can check the wiring. Unplug the refrigerator and gently pry the the dispenser away from the refrigerator. (Use a putty knife and work around the edge of the dispenser.) Check that the connections are clean and tight. Check the connection under the hinge cover, as well.
If the wiring doesn't have any damage, one of the above boards needs to be replaced. Additional testing will be needed. If you add a comment with the model of your Frigidaire, I may be able to provide information about the parts.
I hope this helps.
Mar 12, 2015 | Frigidaire Refrigerators
8x + 3y = 3 4x + 5y = -23
This is best written as two separate equations:
8x+3y = -23 and 34x+ 5y = -23
Solving the first one for x:
8x = -23-3y
x = -23/8 - 3/8y
Substituting this value for x into the second equation:
34(-23/8 - 3/8y) + 5y = -23
-97.75 - (34)(.375)y + 5y = -23
-97.75 - 12.75y + 5y = -23
-97.75 -7.75y = -23
-7.75y = 97.75-23=74.75
y = -74.75/7.75 = -9.645161
Substitution back into the equation for x:
x = -23/8 - 3/8(-9.645161)
x = -2.875 + 3.616935
x =.741935
Dec 12, 2014 | Bagatrix Algebra Solved! 2005 (105101) for...
I have a Frigidaire Gallery refrigerator model no, FGHS2679KE0 on the temperature control panel the display reads 5Y CE and the alarm is on what does this mean
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
My side by side on the temp door reads 5y CE. I unplug and replug and it is ok for awhile
Thank you for your question, Friend.
Typically error code SY CE, is commonly referred to an issue between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect. - Z
Sep 14, 2014 | Frigidaire Refrigerators
Error message 5y ce
Good Afternoon Cheryl, I am happy to assist you. Could the error code possibly be SY CE? If so, error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the refrigerator. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 30, 2013 | Electrolux EI23BC56IS (226 cu ft) Bottom...
5y CE code on frigidaire refrigerator water/ice dispenser
Dear Sue,
  • SY CE Error Codes is a very common issue : the display board isn't communicating with the main PCB.
  • Unfortunately, there is no way to test which board is causing the problem. That's why this error can be costly.
  • Try to just unplug the refrigerator for 15 minutes and plug it back in to see if the error goes away.
  • If the issue doesn't go away, then you'll need to replace one or two boards.
  • Usually the Main Control Board under the refrigerator behind the kick panel is the part that tends to fail.
  • If you Change the Main Board, it does not work; you gonna have to replace the Display Board.
  • Try buying these board at an online store that accept Returns without conditions up to a year. Go online and put the boards number into any major search engine. Put the # one by one. You will find many sellers. Carefully pick one and do you homework
Good luck and keep me posted please,
JP
Jan 13, 2013 | Frigidaire Refrigerators
If y=f(x)=5x+3/4x-5 , show that x=f(y)
Write the equality in the form y=(5X+3)/(4X-5). Insert parentheses to ensure a correct result.
  1. Multiply both sides of the equality by (4X-5). This gives (4X-5)y=(5X+3).
  2. Open the parentheses as 4Xy-5y=5X+3
  3. Subtract 5X from both sides 4Xy-5y-5X=5X-5X+3
  4. Add 5y to both sides 4Xy-5X-5y+5y=5y+3 or 4Xy-5X=5y+3
  5. Factor the X on the left side X(4y-5)=5y+3
  6. If 4y-5 does not vanish, you can isolate X by dividing both members of the equality by (4y-5).
  7. You get X=(5y+3)/(4y-5)=f(y)
Compare the initial function f(x) and the function just found: They have the same form: X and y have switched places.
Jun 24, 2012 | Mathsoft StudyWorks! Mathematics Deluxe...
Write y= -4/5 x+6/5 in standard form
Clear fractions
Multiply by the LCD (5)
5y=-4x+6
Change it to 4x+5y-6=0. That is the standard (or general form).
Jan 12, 2012 | Mcgraw-Hill Glencoe Algebra 1 Florida...
2005 toyota corolla ce maint. required need to know how to reset.
To reset the system. Turn the ignition key to the "OFF" position with the odometer reading shown. Turn the ignition key to the "ON" position while holding down the trip meter reset knob. Hold down the knob for at least 5 seconds. The odometer indicates "000000" and the light goes off. If the system fails to reset, the light will continue flashing.
Jun 12, 2009 | 2005 Toyota Corolla
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
127 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
