Question about Ruud Heating & Cooling
Heat pump with High head pressure
Head pressure exceeds maximum rating (550) 575+ on liquid line. Runs well in cool mode.But not in heat mode. Heat mode : 110 true suction. od temp=50 liquid line temp= 93 Compressor is drawing 13.7 amps.(RLA is 14.1) Air flow is good in and out. unit is about 18 months old and is matched. coils are clean in and out. Ran with return duct removed to eliminate any return air issues.(no change) Suspected outdoor txv. Got a second opinion. I replaced the condensing unit with my spare unit. (same model , figured I would replace txv at the shop and not have to stand on my head!) The new condensing unit performed exactly like the old one. This doesn't leave much but the txv in the air handler. What am I missing?
  • 22 Answers
HFC-134a ? Critical pressure is 588.9 a . With a 93 LL temp and 575 head, I would suspect 1. Air in system or 2. Ref. has gone critical.
With a 110 psig suction/85 deg.F and a LL temp of 93 deg.F/125 psig
Posted on Jan 14, 2013
3 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: Air flow indoors good.I cleaned condenser, found
sOUNDS LIKE THE COMPRESSOR S NOT KICKIG IN OR THE REVERSING VALVES NOT KICKING IN..
Posted on Dec 08, 2009
  • 18 Answers
SOURCE: high suction press (98psi), normal head press
lower fan speed.....and double check head pressure, sounds very low!!! should be around 250-275.....also make sure the return air grill is large enough.
Posted on Aug 10, 2010
High head pressure on high side, & very low pressure on suction line while heat pump is in heating mode? What is the cause ??
First you need to know that manifold gauges are supposed to be reversed in heat pumps during heating cycle checks. The causes of high pressure are 1. Dirty filters, 2. Dirty coils, 3. overcharged system, 4. obstruction in coolant lines.
Oct 05, 2015 | Heating & Cooling
Amana heat pump 13 seer split system when in heat pump mode once the thermostat is satisfied the head pressure on the high side shoots up to 600
410 a runs at a much higher pressure then r-22. that is still very high. it would take a temperture over 150 degrees to produce it on a idle system.
Feb 15, 2015 | Amana 3.5 ton 13 Seer Split Heat Pump...
Senville mini split displays a "defrost" symbol????
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Apr 13, 2014 | Senville 18000 BTU Ductless Air...
Goodman unit runs and at the a-coil there is a piston where your suction and liquid lines connect. On the liquid side the piston is cold but warm on the other side of piston. A/C unit will not cool.
That piston is the metering device. On the liquid line, before the metering device it is always warm (this is sub cooled, high pressure liquid), but should flash to low pressure, lower temperature vapor once it passes through the metering device. The suction and liquid line never connect together.The liquid line brings liquid from the condenser to the evaporator. The suction line brings super heated vapor from the evaporator to the compressor. Since the unit does run, I'd have to put a gauge on it,but if I had to guess, I'd guess you have high head pressure. Check for dirt or debris on the condenser, check for proper clearance of the condensing unit and check for operation and directional rotation of the condenser fan. This could also be the result of an over charge.
Aug 26, 2013 | Goodman CKL36AR36 Air Conditioner
Keeps overheating and blowing white bellows of smoke out the muffler
White smoke is a sure sign of a blown head gasket.
Haven't you noticed the loss of coolant?
To be absolutely sure, you run a cooling system pressure test.
Basically you replace the radiator cap with a pump and gauge.
You pump it up over the cap rating, and watch for a few minutes to be sure it holds pressure.
A head gasket leak will usually not hold pressure.
Then you try it with the engine on.
When you rev it, that produces the maximum heat and pressure, so a leak will cause the gauge to oscillate every time the leaking cylinder fires.
Jun 12, 2011 | 1990 Daihatsu Charade
I am working on a GE Weathertron Heat pump (Mod# BWB924A100C1; Ser# 264082948). The complaint is it is not heating as well as it once was(running a long time to heat up house). I checked the pressure, the...
It is very hard to charge a heat pump in the heating mode. The pressures are low. It also depends on the outside ambient temp. If you can turn to cooling if inside temp is above 70 degrees. Take a piece of plastic and block condensor till you get your head pressure to about 235. Not discharge temp but liquid pressure near service valve. You do not have a TXV inside I believe. Get your suction pressure up a little more It is not to low on gas. If you have temp meter attatch a lead to suction line. Temo\p should be about 10 to 14 degrees difference Between suction temp and Temp on your suction gauge. If you need a charging chart I can fax you one. Rus
Dec 04, 2009 | Heating & Cooling
AC draws more current in hot mode
If this is aheat pump or reverse cycle unit that amps in heating is to high. Should not go over nameplate amps in heat or cool. Sounds like maybe two things. Overcharge and stopped up coil on the inside air handler. The reason for the high amps is in heat the head pressure is higher than normal. So check the coil inside and have the charge checked because that compressor wont run long pulling that much amps over nameplate. Keep in touvh Rus.
Nov 25, 2009 | Ruud Matching Split Air Conditioner
Running high head pressure in heating cycle runs fine in a/c cycle
Check your indoor air filter. When the unit is in heat pump mode the indoor unit is cooling the air, ie. removing the heat from the unit. If the air flow is restricted then the unit will run high head pressure. If the filter is clean then maybe something else is restricting the air flow of the indoor unit. The other possiblity is that the unit is over charged. When in cooling the overcharge will not create the problems that it will in heating mode. The only proper way to charge a heatpump is to remove ALL the refrigerant and then wiegh in the proper amount of refrigerant into the system.
Nov 19, 2009 | Heating & Cooling
Normal in cool cycle, very high pressure in heat cycle
Expansion valve on the condensor or possibly overcharged with refrigerant?
Nov 01, 2009 | Goodman Heating & Cooling
Cooling system
Are you loosing water?  Have you changed the Radiator cap.  May not be holding pressure.  Water boils faster when it is not under pressure.  Does the heater blow hot when you turn it on full heat?
Oct 27, 2007 | Baby Gear
Heating & Cooling Logo
271 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
