Question about Ricoh Aficio AP3800C Laser Printer
Black printing, parts of page not printing clearly
When printing black certain parts of the page dont't print very clearly (white streak effect in certain parts) .We have recently changed the black drum unit, to clear a problem with black lines showing. That problem has gone leaving this other issue. Its almost the reverse of the issue solved.
I have looked at the black develpoment unit, and when you turn the mechanism you can see toner coming out evenly, so I don't think it is that part.
Other colours seem ok, so I assume all is well at the fuser end.
Please help?
Cheers,
Simon.
  • 2 more comments
  • SimonCC Jan 26, 2009
    Hi
    Not sure what you mean by 'tungsten wire unit'? There is nothing in the parts list described as this. There is a fusing unit, which has been replaced recently, but if that was the problem, then I would expect it to cause a problem for all colours, its only black. Problem is there for every page.
    The only replacement parts for black are either pcu or development unit
    Regards,
    Simon.
  • SimonCC Jan 27, 2009
    See other notes added, helper must knwo the part of the Ricoh 3800C
    This is not a problem with the toner cartridge. There isn't one, but there is a BLACK PCU, and black development unit. I can confirm toner is been evenly distributed to the black pcu drum, across the full width of the drum.
    As mentioned, if anyone is able to help they need to know the machine.
  • SimonCC Jan 28, 2009
    I guess there is nobody out there who is familiar with this printer Ricoh 3800C. There is no point in offering advise if you are not familiar with the printer.
    General statements are no use.
  • 2,071 Answers
Just click this site for more information
P { MARGIN: 0px } UL { MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px } OL { MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px } http://articles.techrepublic.com.com/5100-10878_11-1043850.html
Regards;
Posted on Jul 07, 2009
  • 199 Answers
Have you tried Printer maintenance?
head cleaning or alignment.
Posted on Jan 28, 2009
  • 565 Answers
This is the problem of cartridge drum shange it or clean it
Posted on Jan 27, 2009
    Sergeant:
  • 320 Answers
There is nothing wrong with your printer.. Only thing you need to do is clean the printer and make sure there is no dust inside the printing block.. For cleaning the printer, use the below link..
Thank you......
  • Ricoh Master
  • 19,396 Answers
Test a replacement black toner unit, after cleaning the inside of the printer (see
Clean your laser printer safely with these tips)
If you still get the problem, then test the high voltage unit that powers the fuse, color toners fix at different temperature than blacck ones.
If instead of faded , part of black print is missing completely, that can also be a defective laser controller.
Also a new drum that is slightly defective can cause same problem, but that is unlikely.
    President:
  • 2,559 Answers
Have you already took the following steps?
  • Solid lines are printed as broken lines.
    • PCL 5c/PostScript
    Change the [Dithering] setting in the Advanced dialog box
    under the printer driver's [Print Quality] tab.
    • RPCS
    Change the [Dithering] setting under the [Image Adjustments]
    tab in the [Change User Settings] dialog box, under
    the [Print Quality] tab in the printer driver's dialog box.
  • Some parts of the print image are not clear.
    Make the image density darker.
    To adjust the image density, press {Menu} on the control panel,
    and select Image Density from the Maintenance menu.
  • If the color of the printout is different from the color on the
    computer's display
  • Check
    The toner based color settings with the printer driver (causes
    a drastic change in printout color.)
    Changing the color settings with the printer driver (causes a
  • Randy Hough
    Randy Hough Jan 27, 2009
    Also,Are you getting any error code?
  • 39 Answers
It seems like you just need to clean the heads....if you go into your printer settings you should find options for alignments, cleaning and the like....just click clean print heads and you should be fine...
  • Ryan Peterman
    Ryan Peterman Jan 29, 2009
    no im sorry i coulldnt help
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear to be limited to the black only. If so, then corrective action should be limited to the black toner cartridge. Remove cartridge, shake vigorously to evenly disperse the powder inside, break & crumbles gummed/solidified powder. Worst case scenario, a replacement may be required.
Pls post back results. Good luck and thank you for using FixYa.
Posted on Jan 23, 2009
    Guru:
  • 859 Answers
If these are consistent across all pages, I would call into question the state of the tungsten wire. As to whether it was clean. As it heats up the way it does each time it doesn't make sense that dirt would get on it but it can develop blemishes that cause this problem in laser printers and copiers.
Did you replace the heat unit (the tungsten wire unit) on schedule as described by your manufacturer? You may give it a visual inspection for color continuity, but these too are only good for so long, much like a drum unit. And as you have had to replace the drum unit the heating element would be logical to replace as well.
Sometimes, replacing one part reveals another failing part, like peeling an onion, they stack in layers.
Regards,
Worldvet
    Brigadier General:
  • 3,614 Answers
may i know what the exact unit you have there..?
for an intial help, DO a a printer head cleaning maintenance to your printer.
  • micromaster
    micromaster Jan 23, 2009
    Inkjet printers often having clogged print head cartridges. The problem might be because a layer of thick ink might have blocked the holes of the printer’s head.
    First thing TO DO;
    I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
    TO DO;
    1. Remove the ink cartridge from the printer, you can use the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge.
    2. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer.
    3. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer’s option in order to clean the blocked holes of the cartridge.
    4. Run print tests first and once you are satisfied with the results, you can start using the printer normally.
    By using a syringe and some alcohol to unblock the holes can also be very effective.
    Follow this simple steps;
    • Step 1: Remove the cartridge from the computer
    • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
    • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
    • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
    • Step 5: Run some test prints before using the printer normally.
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
When you change the print heads for a Hp L7580 what problems does it resolve?
Replacing the print heads fixes any poor print quality you are experiencing. Typically people replace print heads when a certain color (most likely black) is printing very faint or streaky. Over time the nozzles in the print head can get clogged with dried up ink. Enough clogged nozzles will inhibit ink from being deposited on the page in certain areas.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Dirty printing
1) try cleaning the heads this is usually a job within the printing programmes,
2) using a cotten wool Q tip "the baby typr" and metholated spirits "do not use white spirits or turps too greasy" clean the inside "tram rails " that the carrage slides on "
dont use to much liquid though"
also bleach is very good at removing opld ink that lays on the rails " it is time consuming but well worth the time
Aug 16, 2009 | HP LaserJet 4 plus Printer
Not printing properly
1 try printing from the adf feeder
2 try printing from the scanning glass
if from one of the above method has the problem try to clean your optics
if streaks comes from both u might have problem with the following parts
the charger unit- service it
the toner cartrigde- try a new one
the transfer roller - its is a black roller of it becomes white replacement is needed.
May 05, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Without actually seeing a print sample or the machine, my bet would be on the black print cartridge. Even though it reads a an acceptable level of toner, the cartridge itself sounds like it has developed a proble. 1. It's the most obvious 2. It't the cheapest place to start. If it does not correct the problem, you can still use it later. 3. It's the problem in about 80% of these types of cases. 4. I know it should be fine, but if things didn't go wrong, I wouldn't have a job! Let me know. If not we'll investigate further. Ed
Ricoh Aficio AP3800C Laser Printer Logo
69 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
