Question about Sharp AL 1631 Copier
Red drum light on copier not working
Open end door copier reset but will not copy before red drum light keeps coming back on.
  • Sharp Expert
  • 337 Answers
Are you talking about the light inside near the drum (the laser) or the maintenance light?
Posted on Jan 30, 2013
  • 62 Answers
SOURCE: Drum light
clear exposure clear exposure 24 start 7 start clear twice.
Posted on Mar 23, 2008
  • 1297 Answers
SOURCE: The 'replace drum' light on my Sharp AL-1457
You be must perform the AIDC set(Automatic Image Density Control),and reset the PM(maintenance counter).
Posted on Oct 03, 2009
Sharp Tech
  • 63 Answers
SOURCE: Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Posted on Oct 16, 2009
Testimonial: "Wow! A solution to my problem with a copier was posted within a couple of hours, and the procedure worked perfectly! Thanks. OB "
wheatlandsvc
  • 1110 Answers
SOURCE: sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Posted on Oct 21, 2009
Testimonial: "SUPER!!! IT WORKED, THANK YOU, VERY HELPFUL VERY EFFICIENT, THE BEST"
tessabilisim
  • 9 Answers
SOURCE: Sharp AR-BC260 color copier, the copier is leaving
magenta drum değiştir
Posted on Dec 01, 2009
Printer Problem
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
power off and open front door
hold down the continue button as you power on printer leaving front door open
when error light comes on release continue and close front door.
toner low, load paper, ready, and continue will all be lit.
press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change
when just toner low is lit, press and hold continue button until lights cycle up and down in sequence.
release continue.. toner low will be lit again
turn printer off, wait 10 secs or so and then back on
press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Apr 09, 2014 | Dell 1720dn Laser Printer
The copies come out with dark background, how do I service the machine?
There really is not a service mode for this copier. Have you tried to adjust the flush knob on the control panel? The copier is kind of old, when you **** shell it open is there a black small knob on the inside front of the copier.... If so adjust that... Also, I would try to clean the optic's of the copier under the copy board glass. There is a "VR" on the back of the copier to adjust the lamp. Finally, have you replaced the drum unit???? Good Luck
Jun 08, 2012 | Canon Office Equipment & Supplies
The red drum light is blinking and it will not make copies
HI drum is reach for end of life thats why drum light is blinking you shuld have to replace the drum or just reset the drum counter to run your machine for another life .
thanks
May 11, 2010 | Sharp AL 1631 Copier
Drum light keeps appearing
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover
Mar 31, 2010 | Brother HL-2040 Laser Printer
Black text only printing dark on right side of page. I jsut put in a new black toner cartridge
My solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Feb 04, 2010 | Samsung CLP 300 Laser Printer
Have a brother mfc7440n and it keeps displaying "drum ending soon". have replaced the drum, but keep getting same display
You need to reset the drum counter.I'm not sure that working with your model but try it.
Try opening the front door cover and keep open. Then pressing clear, it should say replace drum, press 1 for yes, it should then say accepted, close cover and turn off.
Oct 08, 2009 | Brother Office Equipment & Supplies
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
Drum light
You need to reset the drum count. Open the toner door. Hold the "Go" key until all 4 lights light up. Let go of the button and close the door. That should reset the drum count and stop the blinking.
Jun 11, 2008 | Brother HL 5140 Laser Printer
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
