Question about Hoover Company Wind Tunnel U53019 Upright Vacuum
Hoover wind tunnel the red light dirt finder stays on
    Scholar:
  • 108 Answers
There's a microphone inside the tube the dirt runs up. It listens for dirt coming up the tube. They just go bad and there's no making it better. You can either replace that entire assembly or ignore it. Fairly easy to replace. I'll include the part so you know what you're looking at.
Good luck! The Vac Dr.
http://vacuummedic.com/product.php?id=481
Posted on Jan 14, 2013
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Hoover Dirt Finder (light) not working
Good be a bad sensor, but if less then a year old, it is under warranty. I would take it in to a warranty repair shop and have them fix it.
Posted on May 13, 2008
Buffalo12980
  • 625 Answers
SOURCE: Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Posted on Sep 22, 2007
SOURCE: My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Posted on Jan 20, 2010
SOURCE: hoover windtunnel dirt finder light stays red
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
Posted on Jun 27, 2010
Hoover - Red Light Dirt Sensor
check to make sure the settings didn't get inadvertently switched to the hi position, move the switch back and forth from high to reg a few times, then leave it on reg.
remove and hand wash the primary filter and secondary filter, dry throughly and replace them in the vacuum.
if none of this works, you will need to have the vacuum serviced, or if it is still working, just don't pay attention to the dirt-finder. the dirt sensor on your vacuum is located in the suction tube and is generally not accessible enough to clean without taking the vacuum apart.
hope this helps,
trin
Nov 20, 2007 | Vacuums
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Embedded dirt finder light stuck
The Hoover uses a small microphone that is positioned in the plastic housing that the end of the hose fits into, just behind the bag compartment. What happens is that when dirt comes up the hose and hits the 90 degree corner, just before it enters the bag, the microphone picks up the sound and transmits that info to the electonics that controls the lights. Sometimes the microphone will stick and the red light will stay lit. If you take a screwdriver and give the microphone area a sharp tap with the handle of the screwdriver, this will often jar the microphone and it will begin working again. If not, it may need to be replaced. NOTE: this function does not affect the cleaning efficiency of the vacuum. Your vacuum will still work normally whether the dirt sensor is working or not. It is a totally unrelated function to the vacuum itself.
Dec 31, 2007 | Vacuums
Dirt finder
The sensor may be bad, or it may be coated over with dirt. Re,ove the hose at the back of the vacuum, the head of the sensor is down inside that opening, reach in there and clean it off and see it that corrects the problem, if not replace the sensor.
Oct 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Embeded Dirt Finder
Sep 19, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Savvy
Does this happen at both Dirt Finder Sensitivity settings?
Sep 16, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover Company Wind Tunnel U53019 Upright Vacuum Logo
292 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
