Question about Natuzzi Milano Leather Sectional Sofa, 2 Piece 117W x 82D x 35H
How do you separate the two sections of the Natuzzi Milano?
Need to move the L-shaped couch but don't find where the two pieces are attached.
I just bought a HOPEN bed from from Ikea. I am following the instruction manual; however I seem to be missing a piece. They are asking me to attach the SKORVA midbeam, but I don't see it here.
I also have the same bed frame from Ikea. The SKORVA midbeam is a separate piece (included in the price of the frame), but sold independently. Make sure to go get both this piece and a slatted bed base (if you haven't already).
Aug 16, 2012 | Furniture
I have an Electrolux Washing machine, model FWSB6600FS1 and serial XC73403943, 60 HZ, 10 AMPS top loading The spinner in the middle came off when I pulled a clean, wet down comforter out. Can't...
ok thats your fabric softner dispenser....the flat round disk shape peice goes in first push it rite in agitator until it is seated firm..the other two peices go together snap the bowl shape piece over the cup shape piece..and snap the hold thing ontop the agatator...good luck
Sep 07, 2011 | Washing Machines
Don't know how to attach a screw on to my corded Skil 3/s drill. Is there a special bit for this purpose?
Hi auntygamma,
Welcome to fixya!
Yes, you need to use a bit with all drills. They come in different sizes and shapes. If you don't have any bits to put into your drill, an all purpose kit would be nice to have. You can find them at your local hardware store or online.
Check out this webpage: http://www.toolup.com/dewalt_dw2163_37-piece-screwdriving-set-with-tough-case.aspx
Copy and paste this entire web address into your browser and a page with one of the kits on it will open up for you. You don't have to buy a kit with lots of bits, you can pick up just one or two bits that you would use the most at the hardware store. The most used bits would be the #1 and #2 Phillips bits and a couple of different sizes of flat bladed bits. A few drill bits might come in handy too.
The drill that you have has a keyless chuck. This means you don't need any special tools to put in a bit or change one. If you look at the chuck, you'll see that the ridged part has two sections. If you hold the back section with your left hand, you can turn the front section to either open the chuck or close it to put bits in.
I don't know if this was clear or not, but if you have any problems or more questions about this, please be sure to reply back. I'll be glad to help you.
Thanks,
Handie Andie
Aug 14, 2011 | Craftsman 3/8" Corded Drill
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 15, 2011 | Office Equipment & Supplies
My airconditioner runs all the time until it freezes up the compressor will not shut off and let the unit run on fan only. when cleaning the unit i desturbed a oval shaped piece of metal connected to a...
If you look in front section when ceiling cover is off, there should be a probe about 2"-3" long stuck in the fins a couple of inches up from bottom, or a round disc like piece with a clip to attach to tubes in the fins. That is what senses frost on fins and shuts compressor off. Should have 2 small wires attached. Look closely up there with a flashlight near lower part of fins and you'll see where it was pushed in for attaching.
Jul 10, 2011 | Coleman Heating & Cooling
Gsd3320 - makes sounds as though it is washing , will not drain water in it and does not seem to be adding water either. Unit is 12 years old
When the drain solenoid fails on most of the GE/ Hotpoint/ Kenmore models they don't
pump out the water. It is located under the dishwasher and has a small triangle shaped
piece attached to a shiny shaft, if this does not move freely then it has failed.
You can often see black spots on the shaft and smell it as well if the coil fails.
Make sure power is off at the breaker before servicing.
They usually come off by removing the "C" shaped clip and the two Philips head
screws connecting the plate to the plastic pump body.
The assembly slides forward. They are around 40 dollars retail.
May 03, 2011 | GE 24 in. GSD3320 Built-in Dishwasher
Reattaching the blades
The blade (the small one with several holes) gets attached to the slide spring (the thin pieces of metal with a small gap between them), through the two diamond shaped holes, with tension on the slide spring keeping the blade in position. The blade guide, the large plate with only two holes, gets mounted with the two screws. The rough surfaces of both blade and blade guide face each other.
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide.
Feb 21, 2011 | Oster 78950-100
How to assemble microfiber sectional couch
I need help assembling a microfiber section couch. I had the chaise on the left side (when looking at it from the front) of the couch and would like to move it to the right side of the couch. I can't figure out where to put the back pieces of the couch to fit right. PLZ HELP
Mar 09, 2010 | Viking Cooktops
Need help attaching vac hoses to shampoo couch.
Here are the instructions. But please be very careful and shampoo an inconspicuous area prior shampooing entire piece of the furniture.
Sep 27, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How do I attach and use the shampooing attachment so I can clean my couch?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=579274
How do I attach and use the shampooing attachment...
Posted by rottylvr on May 08, 2008
I have a Kirby Vacuum and Carpet Cleaner that I know how to use, all except the attachment that I am not sure about. I am not sure if it is a vacuuming attachment or can I attach it and use it to clean my couch, I do not have the user guide for my vacuum as I got it from my son's ex girlfriend in lieu of money she owed me. It looks like it should be used for shampooing things like stairs and furniture, but for the life of me I cannot figure it out! Can you please help me? Tell me how to attach it if it is supposed to be used to clean stairs and furniture or tell me where I can find the user guide to look at and see how to use it......Oh by the way I have a 160 pound rottweiler that tries to live on my furniture and my couch is in desperate need of cleaning, this is my only day off and I have spent all day cleaning carpets due to my dog and would love to clean my couch before returning to work and putting my dog in the back yard now that it is warm enough for him to be outside all day.
Thanks,
Desperate to reclaim her couch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. Also, there is a separate shampoo head that will be in the owner’s manual, you remove the vacuum head and bag assm and attach the shampoo head, make sure you use genuine Kirby shampoo for the carpet. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Natuzzi Milano Leather Sectional Sofa, 2 Piece 117W x 82D x 35H Logo
677 people viewed this question
Top Natuzzi Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Natuzzi Furniture Expert? Answer questions, earn points and help others
