Question about Motorola Mobility Electrify u.s. Cellular Smart Phone 3g With 8mp Camera
Motorola connection error
The following error has prevented a successful connection: Incorrect username or password. Visit settings to Correct.
How do I connection settings under the enternet
What to Do:
  1. From the Nintendo DSi Menu, tap on the "System Settings" (wrench) icon.
  2. Tap the right arrow twice and then tap on "Internet."
  3. Tap "Connection Settings."
  4. Tap on "Advanced Setup."
  5. Tap on an empty connection file.
  6. Click on "Search for an Access Point."
  7. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
    • If you're unable to locate your wireless network, click here.
  8. Tap on the name of your wireless router or access point.
  9. If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
    • If you receive the error message "That data you entered is incorrect," click here.
  10. Tap "OK," "Save Settings," and then "Yes." The Nintendo DSi will perform a connection test.
    As long as you see "Connection test successful," the support code does not matter and can be ignored.
Nov 23, 2014 | Nintendo DSi Black Console
HP Office jet Pro L7780 and windows xp on first pc and vista on other pc Problem: setting up direct digital filing so that I can scan from all in one machine to a shared folder on one of my computers and...
Greetings,
You have 2 computers (XP and VISTA)
Where is the All In One Printer directly connected ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | HP Office Equipment & Supplies
Tip
How to Fix Juno Webmail Error 691: Invalid Username and Password
When using the Juno webmail services, you might get the connection failure issues, as the member ID or the password you have entered is wrong. This problem is also known as the Error 691: Username and password incorrect. At such time, you need to input the password all in lower case letters. If the password isn't working, check that the Caps Lock key isn't active. If you forgot the password, ask the solution of experts just by dialing the Juno customer phone number. As many factors can cause error 691: invalid Member ID or Password, so follow the listed guidance to diagnose the cause of the error and solve them out instantly.
1.Check the Member ID and Password
Make sure that you're entering the correct Juno user ID and password. Also, ensure that you have entered the password into lowercase letters. If your password isn't accomplishing, make sure that the Caps Lock key hasn't yet been activated. If, however, you forgot the password, then you can change it under the supervision of experts.
2.Ensure that Juno Webmail Account has Correct Configuration
If your Juno webmail account was created correctly, the new account information should appear at the end of the confirmation screen. Additionally, if you have logged into the account successfully as earlier, it must be correct.
3. Check that you haven't set the password in Juno software
Do you have the program to configure to remember your Password automatically? In most cases, the password present into the Juno program may be changed. It can happen, if, for instance, you have pressed a key accidentally on the keyboard. If you're sure that your account password is correct, remove the currently set password from the software and re-enter it. This step would solve the error if the password were changed accidentally.
4. Make sure that the access number is correct
To make a successful login to the Juno webmail account, it's necessary to make sure that the access number of your area is valid. When choosing the access number, it may be the area code or placed in the general geographic region rather than local numbers. You may experience extra telephone charges if you select access numbers that aren't covered by the local calling plan.
Note: - You're only responsible for several telephone charges associated with accessing the services. Juno will not refund you for such costs, such as toll charges or long distance.
5. Check Juno webmail version
Do you have the new edition of Juno webmail program? If you're unsure about the Juno version, you can seek the help of IT professionals or go to the Juno official site to know the step-by-step direction to check the version.
6.Test the encryption settings
If you're running the Windows 98, 2000, ME, or XP:
    •Double-click on the 'Computer' icon on the desktop, followed by the 'Dial-Up Networking' icon.
    •Click on the Juno icon to select it. Choose 'Properties' option from the 'File' menu.
    •Choose the 'w Server Types' tab and make sure the 'Require encrypted password' option is not checked. Click 'OK,' and then 'OK' again. If you're still facing issues with the Juno webmail account, call on the Juno support number and seek the technical assistance to solve out all problems instantly and efficiently.
How to Fix Juno Webmail Error 691 Invalid Username and Password
on Apr 13, 2017 | Miscellaneous
Help yahoo com
Symptoms You can try these basic steps to troubleshoot Mail on your iPhone, iPad, or iPod touch. If you see a specific error message, follow the basic steps, then the steps for that error message. For example, you might see one of these messages:
  • Cannot get mail
  • Unable to move message
  • Username or password is incorrect
  • Relaying denied
  • Email address rejected by the server
Resolution First, try these basic troubleshooting steps:
  1. Tap Safari and load a webpage. If you can load a webpage, then your device has Internet access. If you can't load a webpage, check your Wi-Fi connection or try a different Internet connection:
    • Try a different Wi-Fi connection.
    • If your iOS device has an active cellular data plan, tap Settings > Wi-Fi and turn off Wi-Fi.
    • If the affected email account is provided by your Internet provider, see if your issue is resolved while connected to your home Wi-Fi network.*
  2. Log in to your email provider's website to make sure that the account is active and the password is correct.
  3. Make sure your settings are correct using Mail Settings Lookup.
  4. Restart your iOS device.
  5. Delete the affected email account from your device.
    1. Tap Settings > Mail, Contacts, Calendars.
    2. Tap the affected email account.
    3. Tap Delete Account.
    4. Add your account again.
* If you can only use your email account while connected to your home network, this might be a limitation put in place by your email service provider. For help, please contact your email service provider.
Follow the steps below for specific alerts.
"Cannot get mail" Make sure you entered the correct password. If you enabled two-step verification through your email service provider, contact them to see if you need a special password for your iOS device.
"Unable to move message"
  1. Tap Settings > Mail, Contacts, Calendar, then tap your email.
  2. Tap Account.
  3. Tap Advanced.
  4. Tap Deleted Mailbox and make sure it's set to Trash.
  5. Tap Advanced > Account, then tap Done.
    Note: If you see the issue again, repeat steps 1 through 3, tap IMAP Path Prefix, then Inbox. After you make your changes, tap Account, then Done.
"Username or password is incorrect" with POP3 account Before you check your email on your iOS device, close it on your computer and other devices.
To see if your account is a POP3 account use the Mail Settings Lookup tool or:
  1. Go to Settings > Mail, Contacts, Calendars and tap the account.
  2. Look for the label POP ACCOUNT INFORMATION.
If your email provider offers IMAP, remove the POP3 account, then add the account with your provider's IMAP settings. POP3 communicates with one mail client at a time. If more than one mail client tries to connect, you might see a username or password error.
"Relaying denied" or "Email address rejected by the server" when you try to send email This error indicates that either an email address is incorrect or your settings aren't correct for your current connection. Make sure the email address is correct for messages in the Outbox or try a different port:
  • If you're on a Wi-Fi network connected to the same network as your email domain, such as your Cable or DSL provider, try port 25:
    2. Tap your email account, then tap Account.
    3. Scroll down and tap Outgoing Mail Server.
    4. Tap Primary Server, then tap Server Port.
    5. Delete the current port and enter 25.
    6. Tap Done.
  • When you connect to a cellular data or a different Wi-Fi network, you need to use an alternate port and authentication, if your email provider supports it. The most common alternate ports are 465 and 587. Check with your email provider for specific settings.
If you still can't send email, you can set up an alternate SMTP server.
Get help troubleshooting iCloud Mail.
Aug 29, 2014 | Yahoo Mail
Live Mail - xtra mail login
As evident from the message, you are getting the error 0x800CCC92 in Windows Live Mail because the password you had entered is not correct. Or, in other words, the password provided to the email client does not match the account username.
Thus, to solve the Windows Live Mail error 0x800CCC92, you have to double check both the password and the user ID (username) you had supplied when the email account was set up. Please understand that in order to access your email account successfully, the login information has to be correct.
Oct 16, 2013 | Microsoft Computers & Internet
Windows security center
If this is your router and you've forgotten the username or password we suggest that the router be reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Sometimes when attempting to visit a secure website on your Windows computer, you will receive a message about a security certificate error.
You will have the option of whether to continue to the site.
Secure websites, such as an online bank or retail store, use security certificates so your browser knows that any financial or personal information you enter on the website will go the correct place securely.
Every error message does not necessarily indicate a security problem on the website.
Check your computer's date and time.
If they are incorrect, you will receive security certificate errors.
Click on the time in your taskbar, and set the correct time in the pop-up window.
Refresh the website where you received the error message.
If you receive a security certificate error message again, the problem lies with the website's security certificate.
Click the icon that looks like a padlock next to your browser's address bar.
Read the information in the window.
This will detail who owns the website, the site's verification status and any known information about the website's trustworthiness.
Compare this to what you know about the site you were attempting to visit.
Click "View Certificates, then "Install Certificates."
Click "Yes" at the security warning to install the certificate for the website.
May 20, 2013 | Linksys WRT Computers & Internet
Server erro 530 , error on page cause it to work incorrectly
Error Code 530 b> This error code means that FTP authentication was not successful. The combination of the username and password you've typed was incorrect, thus you were denied access to the FTP site. It could also mean a misconfiguration in IIS: You've allowed only anonymous access for FTP, but denied anonymous access for all IIS services. Verify that the username and password you used is correct or check if anonymous access is allowed by leaving the username and password options blank.
Jan 12, 2013 | Computers & Internet
Cannot connect Outlook 2007 to Yahoo server
I had in like situation some times and once I couldn't solve it and luckily for me could find out a good solution to my mind, which determined my troubles quite easily and moreover I hope that this utility will help in this condition too - pst password recovery.
Apr 21, 2010 | Microsoft Computers & Internet
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Retrieving Pictures
You will need to contact your mobile service provider
Sep 09, 2008 | Motorola Mobility RAZR V3
Motorola Mobility Electrify u.s. Cellular Smart Phone 3g With 8mp Camera Logo
Top Motorola Mobility Lands Phones Experts
Motorola Mobility
Motorola Mobility
Eric Sutherland
Level 1 Expert
Ngoro
Ngoro
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
