I have the core so i just found out a when i tried using it yesterdady. I used my friends wireless controller but it would not work. This concerns me because i am wanting to invest in a wireless controller asap or possibly sell my 360. I voided the warranty by opening my 360 up to fix a problem after the warrranty expired in the past. What can I do? Help!!!!?
There are Four Steps. 1. Turn on System 2. Turn on Controller 3. Press and Hold the connect button on the controller (located between the RB and LB buttons) 4. While holding the connect button on controller, press and hold connect button on xbox 360 for about five seconds then let go. (button located to the right of the memory card slot.
Freddy009 thank you so much!!!
Actually most of the suggestions are wrong. I work for microsoft and I bought the Xbox 360 immediately. Just to tell you, take the xbox away from any electrical device (at least 3 metres. Make sure at least 5 hours BE PATEINT! Make sure the xbox is in the upright position and on a solid surface. If this does'nt work you may need to replace the heat baths with a rubber eraser. Hope this helped
The console and controller need to synch. To sync the controller with the console follow the steps below: 1. Turned on the controller 2. Turned on the console 3. Pressed the sync up button on the console 4. Pressed the sync up button on the controller If you have already done that, chances are it is the controller having issues with a different frequency.
By a wireless controller and if it does not work sell the 360 to a private party or to a games store and then buy another one the next day, it may cost you a little cash thought, I'm pretty sure the core is capable of using the wireless controls, or at least it's supposed to be, if you do replace it I highly recomend getting the elite,it'd a little more than the others but its got slightly better hardware, most of the issues from the original 360 are worked out, and its black which looks a lot cooler.
our second remote control won't work on our new xbox 360.
well every time I hit the sync button on the controller and console the controller will not sync
Okay so I've followed all the directions it just not working idk what to do
XETAS - Thanks for your advice it worked instantly, I loved the 4 steps.
