Question about Sony KDL Televison & Video
Sony bravia kdl 40vl160 Blinks in stand By, no power on.
Hi!! Everyone! I do have a Sony Bravia KDL 40VL160 which goes to stand by mode and the red led light blinks 14 times, nothing else happens, it does not turn on and stays there, with out power on. My friend says that the power board should be changed, but i do not know if it could be Firmware fail. Honestly, i do not want to dump it away, because it is a relatively new TV, it has only 3 years old, and out of warranty. Any ideas?
HDTV GURU
  • 261 Answers
SOURCE: Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Posted on Feb 01, 2008
  • 36 Answers
SOURCE: SONY Bravia KDL-52W3000- Quit
Sony are normally pretty good,you just got unlucky i guess,well at least you still got the warranty.
Posted on Feb 03, 2008
  • 3 Answers
SOURCE: TV Goes to Stand-by mode
I don't have a solution, but I have the exact same problem
Posted on Sep 08, 2009
Kensolutions
  • 455 Answers
SOURCE: Sony Bravia KDL-42V4100 42 in.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jul 17, 2011
walesarumi
  • 6993 Answers
SOURCE: Sony BRAVIA KDL-46V3000 Television goes black
This issue is related to a power problem in as much as the TV turns off on it's own. I think the TV has developed a power problem.
The problem is consistent with overheating on the power supply board of the TV.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
This is a common problem faced by many other users too. To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board.
Sony specifically uses GM1 Board. In other words, Sony power supply board is called "GM1 board"
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
You can buy this part at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor (capacitors) most likely the normal operation will be restored. Or you can buy a refurbished complete GM1 power board from shopjimmy.com to save you some stress.
If this task is too technical for you, you can call a family or friend who has the ability to assist you (two heads are better than one).
Posted on Sep 27, 2011
Sony bravia 5 blinks
Hi Tradeboyle,
Please search 'Sony Bravia KDL-40S4100 40 in five blinks' on google and you will get several videos containing the solution of your problem.
Good luck.
May 12, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Hey so my sony Bravia LCD 55" TV if blinking a red light 5 times and won't turn on...... any idea what I need to fix and how? Oh model # kdl-55ex640
HI
if your modal no is KDL-55EX640 & red light is blinking 5 times then your led panel is defective so please change your led panel in this case
Apr 09, 2015 | Sony Televison & Video
When I turn on my sony KDL-52W5100, its acting like its booting up (showing the sony and bravia)then the screen goes blank. Then the red light start blinking 6 time. what do I do/
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
Dec 29, 2014 | Sony KDL-52W5100 TV
I have Sony Bravia 46in model kdl-46w4150 it was working fine then just shut off and red standby light blinking 14 times. I've unplugged and tried to turn back on but still just goes to red standby light...
14 times blinks is a rare case to Sony Bravia sets. Just count it one more time.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 06, 2014 | Televison & Video
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
I have a 2008 Sony Bravia KDL-46W4100 that when I turn it on the red light blinks 14 times. Please help me troubleshoot this problem so I can order the correct part to fix this...
Please help me troubleshoot this problem so I can order the correct part to fix this television
Nov 16, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Televison & Video Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
