Question about Windchaser PARHAL66 Halogen Compact Heater
Windchaser PARHAL66 will not get hot
It will oscillate but does not light the fillament
Windchaser tower ceramic heater model/ cerc1lb
The oscillation mechanism has failed - a frequent problem with this type of heater.
Dec 04, 2016 | Windchaser Heating & Cooling
Looking for replacement parts for Windchaser fan
You can take plumbers tape and wrap about 5 to 8 turns around the shaft threads and put blade on and cap. (Plumbers tape is white plastic tape on a roll with a pop off cap like medical tape comes in)
Remote? Maybe batteries.
Mar 15, 2015 | Windchaser Dryers
Blade broke
Look up zorotools.com and they should have a fan blade you can use it is most anything you can think of so maybe you can find the fan blade you need. Hope this will help Norm.
Aug 06, 2012 | Windchaser 3-way Oscillating Fan
WHAT IS THE ADVANTAGE OF OFFICE 2007 THAN 2003
here is a link stating the advantages http://www.experts-exchange.com/Software/Office_Productivity/Office_Suites/MS_Office/Q_23706879.html
if you have any further questions message me back and please remember to rank how this has helped it allows me to help others in the future with similar situations Thanks Rick
Feb 09, 2011 | Windchaser PARHAL66 Halogen Compact Heater
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Sep 07, 2009 | Windchaser 3-way Oscillating Fan
My Windchaser fan model FTR184 does not work anymore - it did yesterday. The oscillator function still works but the fan doesn't come on. The red light indicating standby mode is lit. How do I get it out...
I have a Windchaser fan mode FTR184 also and it is in the same indicator STANDBY mode and now it will not come on and we have the remote, how do you fix this?
Jun 27, 2009 | Windchaser FTR163 SensorFan Stand...
My windchaser WCUFI wobbles so bad I think it's about to come off
Literally fixed this exact problem on mine today. I couldn't find instructions so I made some on snapguide. Search wcufi-tower-fan/
May 31, 2009 | Windchaser WCUFI WindColumnUltra Tower Fan
Windchaser PARHAL66 Halogen Compact Heater Logo
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
