Question about Panasonic DMR-E85H DVD Recorder
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
  • Stuart Simpson Jan 15, 2013
    update:- when i press record the message "copying of this material is not allowed.cannot record" ?
  • Jim Casas Aug 18, 2014
    no copyright protection is not the case here. Before I got no CODES today I tried using a RWriitable disc and got codes U88 and then U61 and now my disc drawer is stuck open after it's the self-diagnostics kicked in??? It's about 8yr old..probably a spindle problem..after cleaning it using a disc.
It's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Posted on Feb 01, 2013
SOURCE: Faulty Panasonic DMR-E85H
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Posted on Dec 06, 2007
SOURCE: PANASONIC DMR E85H dont startup
I was playing dvd and it just stopped and message came on saying ( please wait) It still has dvd in and cannot get it to do anything
Posted on Mar 08, 2008
  • 130 Answers
SOURCE: DMR-E85H works fine after replacing IC but ......
Quite many possibilities. Since you replaced the IC, I'd figure you have a little understanding of electronics and ESD procedures. You now need to troubleshoot the driver for the display. Do a little research with your DVM... make sure the display is getting V. Should the unit be a uP type system, you are probably looking at the uP display driver circuitry [all in one] being bad and no way around the replacement should you desire a display. Should the unit be slightly older, you may get lucky with finding a cap or transistor problem for the driver. Moreso trans than cap.
Wish it were here.. always easier to take a peak and find the problem when it is in front of me.
Posted on Oct 15, 2008
supertech6
  • 513 Answers
SOURCE: my dvd recorder dmr e85 h panasonic dont rec dont
A DVD Recorder needs to play before it can record. Not accessing the hard drive as well indicates a problem with the power supply inside, more than likely. Time for a reputable repair shop.
Posted on Mar 20, 2010
  • 4090 Answers
SOURCE: my Panasonic DMR-E85H DVD Recorder's hard drive
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
Posted on May 13, 2010
Testimonial: "Thank you."
I have a Panasonic DVD Video Recorder model DMR-E85H manufactured in 2004. It has worked perfectly for all these years but now won't power up at all. I have checked the only fuse I could find inside...
The power supply board is the problem, one of the most common failure is the 1000uf capacitor "open" located near the power transistor that is heat sinked, value may be higher or lower with one or two caps, the second possibility is the power transistor may be open or shorted.
Jun 24, 2011 | Panasonic DMR-E85H DVD Recorder
My Panasonic DMR-E85H DVD Recorder's hard drive has failed, can I replace it with one from the computer store?
May 13, 2010 | Panasonic DMR-E85H DVD Recorder
My dvd recorder dmr e85 h panasonic dont rec dont play movies and dont acces to hard drive what is the problem
Mar 20, 2010 | Panasonic DMR-E85H DVD Recorder
Pan. dmr-e85h turned itself on, self-check
Open case and look for failed capacitors, which are cylindrical and will have a bulging top and a yellow/gold substance leaking out. If this is the problem, search for previous solutions that mention "solder capacitor C1260" for the DMR-E85. I had a similar 'no power' problem with my DMR-E55 and my son and I were able to fix it Sunday. Not hard to do and mine is working again!
Aug 05, 2009 | Panasonic DMR-E85H DVD Recorder
High pitched noise regardless of power on/off
Hello... I would say that your power supply is going bad. But it does sound like the little muffin fan in the unit is.
May 10, 2009 | Panasonic DMR-E85H DVD Recorder
Frozen on the Please Wait
This is a hard drive failure and is expensive to fix, and not worthwhile in my opinion.  Mine packed in with a disc stuck in the disc drive. It was difficult to retrieve. If you have no disc trapped in the tray, I would suggest dismantling anyway and removing the hard drive if you have a load of unwatched content recorded. You can buy a cable to hook it up to a PC - Although I have not done this yet.
DMR-E85H - Rest In Peace.
Mar 18, 2009 | Panasonic DMR-E85H DVD Recorder
Oct 15, 2008 | Panasonic DMR-E85H DVD Recorder
Feb 05, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
191 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
