Question about Samsung R458 R408 R410 R453 R460 laptop fan [KDB0705HA]
Power on of laptop cannot be turn on (samsung)
Power on cannot be turn on.
  • 109 Answers
Step 1:
Unplug laptop from power.
Step 2:
Remove internal battery from laptop.
Step 3:
Plug laptop back in.
Step 4:
Turn on computer as you normally would.
Step 5:
If it starts up on AC power, then battery is dead. Must replace battery.
Step 6:
If still not booting up, then must check the AC adapter for output (use voltmeter). If no output power on AC adapter --> Replace it.
Posted on Jan 15, 2013
Samsung r430
check on the laptop charger or power source to see of there is power if they are working well,if they are well check power button if its faulty if its working then the problem is the power supply which is faulty
Jun 25, 2014 | Samsung R430 Notebook
Samsung turns off when battery around 50%
battery could be faulty,but if it keeps shutting down even with the mains in it could be over heating check the fan is running,if not clean it out.
May 20, 2014 | Samsung Series 5 Ultrabook Laptop
Unlock scroll lock laptop
you will have to remove the laptop battery and bios battery inside the laptop. then plug in the power turn it on and if it turns on pull the power out. then you can assemble everything, turn it on and it should be fine.
Sep 28, 2013 | Samsung Computers & Internet
SAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Nov 26, 2012 | Samsung R580 Notebook
My samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
Apr 05, 2012 | Samsung R480 Notebook
Hi my Samsung R530 will not turn on. I have the charger in and the battery is charged to 40% and the orange light is on to say that it is charging. I press the on button and nothing is happening, please...
Hi danielgardha,
I see that you are experiencing issues with your Laptop, you mentioned that the battery has %40 charge and that the adapter is plugged in on the laptop to the wall but still you get an orange light, but when you press the power button nothing happens on the machine.
  • Remove the battery and the adapter from the Laptop then press and hold down the power button, this is to drain power from the motherboard.
  • Once the power has been drained from the Laptop, connect the adapter back again but leave the battery out of the machine, then turn the system ON using the Adapter only.
  • If the Laptop turns ON using the adapter only then it is possible something is wrong with either the Battery or the motherboard of the Laptop.
  • Turn the Laptop OFF again then put the battery back in, then power the system again check if it will turn on with the battery and adapter in the Laptop.
  • If the Laptop does not turn ON when the battery is plugged in then you will need to have the system checked for a motherboard issue.
I hope that this will help.
mvincentc
Apr 25, 2011 | Samsung R530 Notebook
How to reboot samsung r601 laptop
Rebooting a Laptop is quite simple. Click on Start, go to the > arrow next to Shut Down, then click Restart. If this doesn't work, then try holding the power button down for three seconds or so. Turning it off by holding the power button will eventually start causing errors in your hard drive so don't turn it off like that regularly.
Feb 22, 2011 | Samsung Computers & Internet
Got a samsung N130 netbook. it powers up but the screen won't kick in. any ideas?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Samsung N13013B Netbook
Samsung Q45 won't start
probably itz the faulty battery, try replacing it..
i guess ur hdd is also detoriating (as itz emitting much noise), beware!!
however, u shld contact ur system admin/vendor/an authorized service center....
Oct 27, 2009 | Samsung Q45 Notebook
Samsung v25
Try to diagnose the problem first...
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
Aug 09, 2008 | Samsung V25 XVC 2800 Notebook
Open Questions:
See all Samsung R458 R408 R410 R453 R460 laptop fan Questions
Samsung R458 R408 R410 R453 R460 laptop fan [KDB0705HA] Logo
82 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
