Question about Pentair 1 HP Challenger Pump
Why is my indoor resistance pool water too hot?
Turned down thermostat and still 94 degrees
    Genius:
  • 1,669 Answers
Thermostat is reading a bad temperature sensor in the water.
Posted on Jan 13, 2013
How do I turn down thermostat on this water heater?
The temperture of a water heater should be approx 120 degrees. If you use a dishwasher that is the desirable tempurture to kill bacteria.
If your heater has two thermostates then make sure they are set for a 5 degree difference between them
Good Luck,
Marty
May 06, 2014 | Rinnai Water Heaters
Jandy lite 2 pool heater. The heater is about 5 years old. Pool and hot tub share the same water supply side. Heater started shutting off at lower and lower tempatures over the last few months. Heater...
if you have not been keeping the water balanced, there may be a buildup in the pipes inside the heater core. this would cause the heater to work harder, produce less heat transfer and cause the over temperature sensor to kick out before meeting the set point.
Apr 01, 2017 | Pool & Spa
Why is my pool water is too hot?
The water temperature sensor is no longer sending the correct temp to the thermostat. Change it!
Jan 13, 2013 | Pool & Spa
ELS 1102-2, THE HEAT CONTROL IS SUPER SENSITIVE. THE SLIGHTEST MOVEMENT HIGHER AND THE WATER IS TOO HOT, THE SLIGHTEST MOVEMENT LOWER AND THE WATER IS TOO COLD. THIS IS A FACTORY INSTALLED...
Mechanical thermostats such as the one in your heater are only accurate between 3-5 degrees once set. Unlike a digital thermostat that is accurate to .1 degrees. You can purchase an aftermarket thermostat for $120 that is digital and can be installed in your heater.
Jan 29, 2011 | Raypak 130,000 BTU Propane Gas Pool...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Intermatic electric water heater timer only gives enough hot water for a 7 minute shower. How do I increase this time?
Try turning your thermostat up 20 degrees. That will make hotter water, requiring more cold to mix so you'll use less hot water for the shower. If that helps but you'd like it longer, increase the temperature in 10 degree increments until you reach a temperature that works.
May 14, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
HOT WATER
Not exactly, the heated water in the tank it self is roughly the desired temperature of the thermostat, there is a variable of 5 to 15+ degrees depending on its calibration. there are other considerations i.e. water heater tank insulation - hot water pipes being exposed to cooler temperatures thus cooling the water in the pipe - the farther distance that the water travels from the heat source, the cooler the water will be at the spigot.
Feb 20, 2009 | Intermatic WH40 - Water Heater Time Switch...
Pentair 1 HP  Challenger Pump Logo
20 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
