How do I replace the batteries in a Sharp EL-512 calculator?
I cannot open the calculator.
informatica
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
vladp995
  • 81 Answers
SOURCE: how to calculate
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
Posted on Jul 06, 2009
SOURCE: SHARP EL-735
There you go mate...http://support.sharp.net.au/downloads/opmanuals/EL735.pdf
Posted on Oct 04, 2009
Manual Sharp EL-512 please
There is a PDF version of the manual for the original Sharp EL-512 Scientific Calculator available for download from http://striegels.com/alan/sharp. Just click on the image of the manual front cover.
Be warned, this is a high-resolution scan of all pages and is not text-searchable. The size of the PDF file is over 13 MBytes. As this was printed in 1981 and there is no copyright page, it may be copied freely.
Feb 21, 2015 | Sharp Office Equipment & Supplies
Get sharp calculator manual el-512
Hi! Try these ones:
1) http://www.manuals365.com/download/sharp/el512h_om_gb.html
2) http://www.usersmanualguide.com/sharp/calculator/page4
Feb 12, 2015 | Sharp Office Equipment & Supplies
How can I open battery compartment to replace battery?
Very carefully, it seems. Two tiny screws on the back of the calculator and then open it up very very carefully;)
http://www.tvmcalcs.com/index.php/calculators/faq/sharpel733a_faq
Good luck,
Paul
Mar 02, 2014 | Sharp EL-733A Calculator
Sharp el-470 travel clock calculator
How do I set the date on the Sharp EL-470 travel clock calculator?
Oct 08, 2010 | Office Equipment & Supplies
Need manual for sharp calculator model el-1197p
You can download the required manual from:
http://www.retrevo.com/support/Sharp-EL-1197P-Calculators-manual/id/358bh050/t/2/
On the page which opens, click on GET MANUAL button and follow the instructions on next page to download the manual.
Hope this solves your problem. Thanks.
Sep 19, 2009 | Sharp EL-1197P Calculator
Sharp EL 531w . the calculator doesn't turn on.
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
Apr 15, 2009 | Sharp EL-531VB Calculator
62 people viewed this question
k24674
jasbo
jasbo
